Team Shelby: BEARING FAILURE NOVI -1200 @ 5000 miles - Team Shelby
BEARING FAILURE NOVI -1200 @ 5000 miles WATCH OUT FOR FOR INCREASED NOISE
#1 User is offline   SHELBYCS6
  • State or Province:ON
Posted 05 September 2008 - 09:29 AM
I have had my Novi-1200 installed for a couple of summers now and have about 5000 miles since the installation.
I downsized the S/C pulley over the winter which I now find out voided my warranty but regardless this is where I now stand.
Even since the original installation I have found the traditional S/C whistle getting progressively louder month over month but it would subside once it was warmed up and everyone including myself thought that was normal.
Earlier in the summer I had pointed this out to DaSilva Racing (local S/C dealer) and was told just to listen for further change.
The noise was getting worse, almost to a low growl and with the Dearborn show next week I decided to remove and inspect the unit as it was a big gamble to take the car out of town sounding like this.
This morning I removed the unit and this is what I found.
The front thrust bearing below the impeller is missing three balls which I assume are now in my oil pan as they were no where to be found but other than a slight rub which had developed between the impeller and the case the rest of the unit looks good.
I'm going to check the impeller shaft for run-out to make sure it's straight so I'll know shortly.
The idler assembly surprisingly uses two 6205-C3 off the shelf bearings but the impeller / drive side uses Vortex high speed angular thrust bearings 17 x 35 x 10 which I'm now going to replace with NSK (Abex7 / P3) bearings which are rated to 60,000 rpm + in an oil bath which are part # 7003CTRDULP3.
These two little bearings are almost $400.00 for a matched set.
I'm also replacing the two o-rings and CR-seal 25 x 40 x 7 with viton as the seal on the drive pulley side appears to be a cheap single lip buna seal.
I'll get a few photos on re-assembly in case anyone here has a similar issue because there is no information on the web for these units and trying to get a live tech person on the phone at Paxton is impossible.
Just received a confirmation From a Paxton representative that they are experiencing bearing issues with these units.
They will most likely be replacing my unit following Dearborn.
I'll still post some photo's of the rebuild this weekend.
This post has been edited by SHELBYCS6: 05 September 2008 - 01:02 PM
#2 User is online   moabman
  • State or Province:TX
Posted 05 September 2008 - 09:49 AM
The idler assembly surprisingly uses two 6205-C3 off the shelf bearings but the impeller / drive side uses Vortex high speed angular thrust bearings 17 x 35 x 10 which I'm now going to replace with NSK (Abex7 / P3) bearings which are rated to 60,000 rpm + in an oil bath.
I'll get a few photos on re-assembly in case anyone here has a similar issue because there is no information on the web for these units and trying to get a live person on the phone at Paxton is impossible.
Great information! Are you sure you had good oil circulation? Hearing those seal materials reminded me it's time to rebuild my scuba reulator :happy feet:
#3 User is offline   SpeedRacer
  • Member #20
  • Interests:Shelby American Registrar
    40th Anniversary GT500
  • State or Province:OH
Posted 05 September 2008 - 02:38 PM
ShelbyCS6,
Current ball bearing designs and materials are meeting their technical limits. i.e., speed, temp, debris environment, etc. We were working with a TC Company on a new design that uses aerospace technology. Super alloy rings & carbonitrided balls. We couldn't get the things to fail; however, since the auto industry is hurting so bad, they declined and went back with the old technology.
Stuart
#4 User is offline   SHELBYCS6
Posted 05 September 2008 - 07:16 PM
View PostSpeedRacer, on Sep 5 2008, 06:38 PM, said:
ShelbyCS6,
Stuart
Hi Stuart....do you work for Paxton or a bearing manufacturer ??
The bearings that are in my Novi 1200 have an inner race, outer race and poly cage but they don't have an outer retaining edge on one side...sort of a uni-directional axial thrust bearing.
The ones I'm installing are a far superior design that could most likely operate in the 80,000 rpm range which would greatly exceed the requirement.
They have had superchargers for many years without experiencing this type of premature bearing failure.
I think it's just one of those situations where the component selected just doesn't suit the requirement and the 1200 series is relatively new to the market.
Unless it is a severe race application with extreme boost, high end matched sets of super precision bearings should be more than adequate for any supercharger application.
#5 User is online   moabman
Posted 05 September 2008 - 07:59 PM
What kind of oil do you run? 80,000 RPM sounds like turbine oil territory - something like 0-20w synthetic.
#6 User is offline   SHELBYCS6
Posted 06 September 2008 - 04:01 AM
80,000 rpm is just the potential, I doubt it would run near that fast.
Paxton indicates straight OEM type engine oil is fine for their applications which sort of surprised me for the increased S/C speed but I have run full synthetic since the S/C was installed.
The bearings I'm installing are overkill for this application but I don't want to take the chance of any further issues until we get this rectified permanently.
#7 User is offline   SpeedRacer
  • Member #20
Posted 06 September 2008 - 04:40 AM
CS6,
I work for The Timken Company, 3rd Largest Bearing manufacturer in the world ($5.5B). You're right, for your application the bearing should be fine. Probably had a material failure--an inclusion that propagated a spall.
Stuart
This post has been edited by SpeedRacer: 06 September 2008 - 04:42 AM
#8 User is offline   SHELBYCS6
Posted 06 September 2008 - 05:38 AM
View PostSpeedRacer, on Sep 6 2008, 08:40 AM, said:
CS6,
Stuart
I figured it was one or the other with the metallurgical definitions for nitrate applications...
FYI....I contribute about $60,000 + to your bottom line annually.....I don't do off-shore where bearings are concerned....
I also utilize a good volume of SKF, NSK, Torrington etc.
Bearings are the life of Hydraulic units and we change them on every single repair.
#9 User is offline   SHELBYGT698
  • State or Province:nc
Posted 06 September 2008 - 02:09 PM
CR/SKF bearings are normally made in India, isn't it? Timken & NTN/BOWER are the only bigger companies I know that have their bearings made in the USA
Correct me if I'm wrong
#10 User is offline   SpeedRacer
  • Member #20
Posted 06 September 2008 - 03:16 PM
CS6,
Thanks for the business! :happy feet: We acquired Torrington in 2003. SKF & NTN :cry: Thanks again.
Stuart
#11 User is offline   SpeedRacer
  • Member #20
Posted 06 September 2008 - 03:20 PM
GT698,
The Timken Company is the last large USA Bearing Company. We have many plants in the USA; however, so do all of our competitors (NSK, NTN, SKF & FAG). However, if you buy Timken your more likely to get a USA made part. Keep buying our bearings, we need you! :happy feet:
Stuart
#12 User is offline   SHELBYGUY
Posted 11 September 2008 - 02:19 PM
Did you talk to Paxton They maybe hard to get in touch with but they spend time with you (that why hard to get in touch with) Even that you voided your warrenty I would give them a call the company is very helpful and did have a limited issue with some bearings.
shelbyguy
