Put a starting mark on it like this.
Then measure out 17-3/8 " and put another mark on it. That is the mark for the start of the fender stripe. Also put a mark at 20-1/8" for the Center of the 1 inch space that goes between the 2 stripes.
This will leave you a piece of layout tape like this.
Then take the piece of tape and put it on your car. Make sure the first mark is at the start of the fender by the headlight like this.
Lay the tape out on the top of the fender to give you the fender stripe locations like this.
To lay out the location of the bottom of the stripes I plumbed straight up from the center of the rim and put a mark on the tape in the following location on the fender crease.
This pic shows the top lay out and the bottom lay out.
I suggest you then use a piece of 1 inch painters tape and apply it to your car fender that will represent the center space (the 1 inch gap space). Then lay your stripe to that leading edge of your tape. Apply one stripe at a time and go very slow and rub the stripe as you go with a wet finger. If your finger is wet it will provide lubrication for your finger to slide on the stripe easily. Go slow and you will not have any bubbles. Rub your finger constantly on the stripe as you go to prevent bubbles.
