Team Shelby: Gear Engagement - 09 KR - Team Shelby
New 2008-2009 GT500KR Parts
GT500KR wheels/tires - more.
#1 User is offline   JerseySandy
  • Interests:American Cars, Motor Sport, Event Management
  • State or Province:UK
Posted 09 June 2009 - 11:34 AM
180 miles in and I find it difficult to engage gear.
Any ideas on what this is or if there is any adjustment needed.
Thanks in advance
#2 User is offline   GT500-07
  • State or Province:MD
Posted 09 June 2009 - 11:42 AM
Thanks in advance
sound's like it's time for the TSB
#3 User is offline   mustang crazy
  • mustang crazy
  • State or Province:LA
Posted 09 June 2009 - 11:53 AM
GET IN IT AND DRIVE IT LIKE YOU STOLE IT AND BREAK HER IN !!!!!!!! :peelout: :peelout: :speedie:
#4 User is offline   09KR0058
  • Interests:09KR0058
  • State or Province:GA
Posted 09 June 2009 - 11:55 AM
Is this any gear at any speed? Based on your info, I'm guessing your dash plaque is 09KR0441. Mine is 09KR0058, and I'm pretty sure that I have the new clutch, based on my build date of 9/30/08. I wouldn't think that your 441 would have gotten the old clutch.
This post has been edited by johnmsch: 09 June 2009 - 11:56 AM
#5 User is offline   JerseySandy
Posted 09 June 2009 - 02:02 PM
Most problems at standstill / slow speeds.
My door jamb says 10/08. I have done around 180 miles. Not hard but gradually building on power.
My dash is indeed 09KR0441.
I imported the car to the UK so any tsb woiuld be fun to say the least.
Thanks to grabber I got the build date confirmed as 10/10/08 so not the tsb issue then - any other ideas ? If a cable assembly is fitted, then being new is there any stretch which occurs & is this adjustable ?
Thanks for your help - most helpful and welcome.
Best Regards
This post has been edited by JerseySandy: 09 June 2009 - 02:06 PM
#6 User is offline   09KR0058
Posted 10 June 2009 - 01:02 PM
View PostJerseySandy, on Jun 9 2009, 06:02 PM, said:
any other ideas ?
No, not really. I'd wait to see how it is after you've driven a couple of thousand miles. With only about 200 miles on it, nothing is really broken-in yet.
#7 User is offline   07-2937
  • Bill
  • Interests:Cars
  • State or Province:NV
Posted 10 June 2009 - 03:45 PM
It has a short throw in it (ford racing) does it feel sloppy? also if you are trying to downshift into first that would be difficult the transmission doesnt like that. it should have a "positive" notchy feel to it when you shift gears but it should not present shifting problems
#8 User is offline   JerseySandy
Posted 11 June 2009 - 11:53 AM
No there is something wrong. for example I can't get it into reverse at standstill. I have to switch off, put it into reverse and re-start. The gear change was super smooth to begin with, now terrible & notchy and difficult to get into any gear.
I'm trying the pump the brake pedal and clutch pedal trick a la Grabber to see if I can work out any air in the line - which I hope to god it is only that.
Apart from that I'm amazed at this car.
#9 User is offline   GT500-07
Posted 11 June 2009 - 12:53 PM
sure sounds like the TSB :headscratch:
This post has been edited by GT500-07: 11 June 2009 - 12:53 PM
#10 User is offline   JerseySandy
Posted 11 June 2009 - 03:28 PM
I have to admit it does. I'll check if I can see which fly wheel is fitted this weekend.
Puzzling ?
#11 User is offline   6-Speed
  • State or Province:AZ
Posted 13 June 2009 - 06:42 AM
A few things to try:
1. Clutch should be FULLY depressed before you shift to reverse. Try adjusting the seat forward to assist.
2. Depress the clutch, then move the shift lever fully to the left (1-2 gate) and then shift into reverse.
You might be encountering the reverse lockout.
However, if it is difficult to get into any gear, your car might be a candidate for the TSB. Does it grind while attempting to shift into any gear?
This post has been edited by 6-Speed: 13 June 2009 - 06:46 AM
#12 User is offline   gc12
  • State or Province:FR
Posted 13 June 2009 - 09:26 AM
What I don't quite understand in this scenario is the fact that the car has been barely driven + it's a 2009 KR built in november 2008 which means it has the latest transmission parts and shouldn't be a potential client for the dreaded TSB. Unless the morons who've already broken the front splitter also managed to screw up the trans. while testing the car for homologation purpose. If this is the case, I would hunt them down until I got all of them by the balls!!
#13 User is offline   Son of GT
  • "THERE'S NOTHING LIKE A SHELBY... NOTHING.
  • Group: Moderator
  • Interests:Most Motorsports, all types of cars and trucks; especally anything Shelby. My country, family, and friends, and all who have served or are serving in the military defending the U.S.A. Still and video photography; and of course morally casual women!
  • State or Province:CA
Posted 13 June 2009 - 09:42 AM
Best Regards
Unfortunately, there is no clutch cable to adjust, the system is hydrolic. Based on your build date, it appears that you have the 2nd generation clutch assembly in your car. Having said that, and considering the issues you are having with the clutch/transmission, I would venture to say that you have air in the system. Try pumping the clutch pedal several times next time to see if that helps shifting, and if it does, then I recommend that you have the master and slave cylinders bled.
Hope this helps.
#14 User is offline   JerseySandy
Posted 15 June 2009 - 11:13 AM
Hope this helps.
It does help - I checked under the car today and it definitely has the new flywheel.
So to ask another question - how are the clutch and master slave cylinders bled ?
I think this may be the answer.
Kind Regards
#15 User is offline   08GT500KR
  • The Economy will improve, Ah, I hope.
  • Interests:American made muscle
  • State or Province:Mi
Posted 22 June 2009 - 05:30 PM
Kind Regards
Hmmn, a Z06 is tempting
#16 User is offline   sharabi
  • State or Province:MI
Posted 03 July 2009 - 05:03 AM
If she sounds like screaming pig when you fire her up that is when i think of air in the lines that needs to be bled, it sure sounds like TSB and am surprised if that is the case how the dreaded flywheel found its way to your late built date. and if as you said that it is the new flywheel that makes the puzzle more interesting. please keep us posted.
http://www.teamshelb...l=screaming+pig
This post has been edited by sharabi: 03 July 2009 - 05:10 AM
#17 User is online   DDT
  • Dave
  • Interests:"Don't blame me"......."What did I do"???????
Posted 03 July 2009 - 07:47 AM
Maybe the new stuff is not improved???????????
#18 User is offline   sharabi
Posted 03 July 2009 - 08:28 AM
That will be puzzling if it is new flywheel and same dreaded problem. sure sounds from the symptoms that they are typical of the clutch failure. but no jumping to conclusion and i will be interested in knowing what the dealer say about it.
#19 User is offline   KR_Mac
  • State or Province:Ca
Posted 11 September 2009 - 03:38 PM
Quick question... I have an 08 KR (08KR0224) with build date of 9/08 ... i saw the post here for an 09KR361 with build date of 7/08 on the sticker... does that sound correct. Im just asking cause i wanted to know if i had the new or old clutch... thanks. I dont get the order of CSM... seems like its all disorganized ?
08KR0224
