Team Shelby: Dual fan assembly - Team Shelby
Dual fan assembly Is there a replacement?
#1 User is offline   BobsShelbyDakota
  • State or Province:NV
Posted 27 August 2009 - 01:13 PM
Hello all,
In case I can't get ahold of an original dual fan assemby for my S/Dak, is there a type that would be thin enough to fit in there? Does it have to be a dual fan or will a single one suffice? Hopefully I can get an original but since I am getting ready to pull the engine and rebuild it I want to have something to install before I drop the rebuilt engine back in.
Bob
#2 User is offline   greaser
  • State or Province:mn
Posted 28 August 2009 - 03:43 PM
View PostBobsShelbyDakota, on Aug 27 2009, 04:13 PM, said:
Hello all,
Bob
any of the newer single fans made for V8s should work fine.
#3 User is offline   GLHS0136
  • State or Province:ca
Posted 28 August 2009 - 06:37 PM
Well, if your gonna sandwich the fan between the condensor and radiator like the originals, i would go 2. Being sandwiched in there like that, they can't grab air and they can't push air efficiently. The fans are real loud when they turn on because of it. I pull an 18 foot car trailer with mine too, so it will get pretty warm on a grade such as the grapevine or going in and out of Vegas on 15 through the hills. So, I run water wetter and the dual fans and get great results.
Robert
#4 User is offline   shelbymotorsports
  • View blog
  • Group: Moderator
  • State or Province:CA
Posted 30 August 2009 - 02:51 PM
Bob
Do you have the original fans & fan housing in the truck now?
#5 User is offline   Phatnlow
  • Mr. Phat
  • Interests:I love restoring,customizing autos and showing and owning rare productions.
  • State or Province:nc
Post icon  Posted 22 February 2010 - 10:34 PM
Hey Bob since your going to rebuild your 318 engine. I thought i'd pass along alittle info if you haven't found out already the 318 in the s/d is a little different than the normal 318 used in fullsize trucks later years. I went to a mopar site and e-mailed them making sure. There is a different cam used and some other goodies. a guy on their site rebiult his 318 as well and noticed the differences and posted them on the site. I will goto my favs and post it here later
#6 User is offline   sdac guy
  • State or Province:mi
Posted 24 February 2010 - 05:46 PM
The other thread about this topic had an adequate answer. But to go further, Allpar is not necessarily known for always having accurate info. Anybody can post up what they think about their car or truck and generally no verification for accuracy is done.
The 318 in the Shelby Dakota had one or two external mods from the engine used in the 89 Ram. The oil pan being switched to accommodate the cross member in the Dakota was one mod, the removal of mechanical fan assembly from the water pump mounting is another. But internally the engine is identical to the 1989 Ram engine. If someone takes one apart and finds something different, it is very likely the engine was modified by a previous owner.
The engine electronics used were also exactly the same, except it was modified for the electric fan control. Using the same engine and controller from the 89 Ram allowed Shelby Automobiles to produce the Shelby Dakota without the added expense of putting it through the full EPA emissions testing. It only needed a simple certification for use in the Dakota body.
This post has been edited by sdac guy: 25 February 2010 - 07:27 PM
#7 User is offline   nemiro
  • Engine Control Freak
  • State or Province:NM
Posted 24 February 2010 - 07:00 PM
IIRC, the changes to the 318 came when it was officially called the Magnum 5.2L. There were several changes to the heads, mounting bosses, and the camshaft. If it were up to me, I would be looking to jump to the Magnum line, preferably to the 5.9L, and adapt the earlier bolt on parts to work properly. Much more support for the newer engines, and the power difference in the torque department is a worlds of difference from the two engines. I had a 96 Indy Ram with the 5.9L, and it was a very reliable, tough engine. My brother in law owns it now, and he did not take care of a coolant leak. It lost all the water. Him, not being mechanically inclined, simply put his foot down harder when it started to 'bog and lose power'. After 5-10 miles of this, it locked down. After it cooled, we put water in it, and changed the oil. It's still driving around 2 years later.
#8 User is offline   BobsShelbyDakota
Posted 26 February 2010 - 01:57 PM
Thanks, appreciate it.
Bob
