SAVE 30% ON SELECT SHELBY PERFORMANCE PARTS. CLICK HERE TO LEARN MORE.
IPB
Welcome Guest ( Log In | Register )
TEAM SHELBY
| JOIN / RENEW
Site Map
SHELBY STORE
SPONSORS
SHELBY STORE
SPONSORS
> SAVE 30% ON SHELBY PERFORMANCE PARTS
SAVE 30% ON SELECT SHELBY PERFORMANCE PARTS. LEARN MORE HERE.
5 Pages V  « < 3 4 5
Reply to this topicStart new topic
> Front Brake Pads, What do you recommend?
6-Speed
post Nov 15 2009, 04:27 PM
Post #81
Group: Members
State or Province:AZ
A couple of details from the shop manual:
- Position the notch in the caliper piston up and down to align with the alignment pin on the brake pad.
- There is a sequence for torquing down the caliper guide pin bolts after they are snug:
  • RH caliper - tighten top bolt and then the bottom bolt
  • LH caliper - tighten bottom bolt and then the top bolt
This post has been edited by 6-Speed: Nov 15 2009, 04:29 PM
Go to the top of the page
Bookmarks:Post to BlogMarksPost to Del.icio.usPost to DiggPost to FacebookPost to FarkPost to FurlPost to GooglePost to NewsvinePost to RedditPost to SpurlPost to StumbleUponPost to YahooMyWeb
+Quote Post
tispco
post Nov 15 2009, 04:30 PM
Post #82
Shelby Nut
Group Icon
Group: Team Shelby Member
State or Province:NC
QUOTE (6-Speed @ Nov 15 2009, 11:43 AM) *
The rear caliper piston needs to be turned in a clockwise direction to reset. The shop manual identifies an adapter, rear brake caliper piston adapter - 206-026 (T87P-2588-A) or equivalent tool. I have a brake caliper tool set that I purchased from Habor Freight Tools for $20; it comes with a number of various adapter plates. I'm hoping it comes with the correct adapter plate for the rear piston.
The Harbor Freight kit comes with the correct adapter plate and works great. It makes the job MUCH easier. Also, I was able to change the rear pads without removing the e-brake cable.
+Quote Post
6-Speed
post Nov 15 2009, 04:37 PM
Post #83
Group: Members
QUOTE (tispco @ Nov 15 2009, 05:30 PM) *
Thanks for confirming - I have used the HF caliper tool for brake jobs on my other vehicles, but not on the Mustang yet and I agree it works great and you can't beat the price.
(IMG:http://i255.photobucket.com/albums/hh154/Six_Speed/HF_Caliper_Tool.jpg)
This post has been edited by 6-Speed: Nov 15 2009, 04:40 PM
+Quote Post
enormous
post Nov 15 2009, 06:13 PM
Post #84
Member
Group: Members
State or Province:On
Thanks everybody for the rear pad tech tips. Off to Harbour Freight I go.
+Quote Post
enormous
post Nov 16 2009, 11:40 AM
Post #85
Member
Group: Members
I ran into my SVT tech today while at the dealer. The guy lent me is Ford tool needed for the rear pad install. How cool is that!
+Quote Post
jcthorne
post Nov 18 2009, 05:27 AM
Post #86
Member Terlingua Racing Team
Group: Members
This thread got my curiosity up. So I figured its only $54 to find out. I went down to the local AZ and got a set of the Cmax pads. Replaced the Mintex pads in less than a half hour. Bedded them in. I will admit while bedding them in I thought I had lost a good bit of braking performance and was going back to the Mintex pads. Now been driving the Cmax pads for several days and last night got the time to really push them. 100 to 0 four times in a row. Rotors were HOT. DAMN HOT like after a really good track session hot but the brakes never faded and the 4th stop was as smooth and quick as the first. If there is any difference in real world performace between these Cmax pads and the expensive Mintex ones, its so far outside my driving abiltiy as to be a waste of money. And this moning I looked at the front wheels (chrome by the way) still clean at about 400 miles since the pads went on. With the mintex pads they would have been completely black. The Cmax pads are quiet in traffic as well. In fairness, there may be a SLIGHT increase in pedal effort for the brakes but it is slight and modulation/control is excellent. Rotor wear is yet to be seen but pad wear is AZs problem as they are going to be providing pads for the life of this car. I just need to sell a few more sets for them. :-)
I'll hold on to the Mintex pads for open track days but unless I find something I have not seen yet, will be doubtful if I would change them out. I don't really know the composition of the AZ ceramic Cmax pads, but they work very well and dust FAR less than anything I have seen on these cars. Perhaps someone has finally found a ceramic compound that works? I was also impressed with the quality of construction and packaging of these pads.
+Quote Post
rlhay2
post Nov 18 2009, 10:33 AM
Post #87
Member
Group: Members
State or Province:TX
QUOTE (jcthorne @ Nov 18 2009, 07:27 AM) *
This has been my experience too!
CMAX for street driving, and in my case Hawk HPS pad for the track.
I did do one date with the CMax pads, would not recommend do that again....
+Quote Post
jcthorne
post Nov 18 2009, 10:52 AM
Post #88
Group: Members
QUOTE (rlhay2 @ Nov 18 2009, 12:33 PM) *
Please describe your experience with the Cmax pads during a track session. Did they eventually fade at high temp? or did they actually fail? Would like to know what to look out for. I envision these pads have substantial limits but for street use may be just fine. Would like to know how far I can expect to push them.
+Quote Post
03 DSG Snake
post Nov 18 2009, 11:19 AM
Post #89
Member
Group Icon
Has anyone tried the Hawk Ceramics?
+Quote Post
6-Speed
post Nov 18 2009, 04:33 PM
Post #90
Group: Members
QUOTE (jcthorne @ Nov 18 2009, 06:27 AM) *
Did you only install the Cmax pads on the front brakes?
+Quote Post
rlhay2
post Nov 18 2009, 04:52 PM
Post #91
Member
Group: Members
QUOTE (jcthorne @ Nov 18 2009, 12:52 PM) *
They did not fail but they got HOT!
And the brakes do fade when the system gets hot.
And that mushy pedal does not invite confidence.
+Quote Post
cubican
post Nov 18 2009, 04:54 PM
Post #92
Member
Group: Members
State or Province:tx
QUOTE (03 DSG Snake @ Nov 18 2009, 11:19 AM) *
I have, and the C-max are much better. One of the hawks pads develop a crack, and half of the pad fell out, Thats when a good friend told me about the C-max, and I had the same reservations like many on here, but the C-max made a believer out of me .Best advice I ever got.
+Quote Post
jcthorne
post Yesterday, 02:25 AM
Post #93
Group: Members
QUOTE (6-Speed @ Nov 18 2009, 06:33 PM) *
Yes, I only installed the fronts as a trial. Will likely replace the rears when next due. I don't have near the trouble with dust in the rears as I did up front. It is odd that there is now more dust out back than in the front....
+Quote Post
jcthorne
post Yesterday, 02:32 AM
Post #94
Group: Members
QUOTE (rlhay2 @ Nov 18 2009, 06:52 PM) *
So your brake fluid boiled before the pads failed? An over heated pad will feel like a hard pedal, more pressue just does not apply sufficient braking force. Soft pedal is fluid boiling. This indicates the pads held up until your brake system overheated. The pads do have a bit of effect on how much heat is transferred to the caliper vs the rotor but I have yet to see even a race pad that was particularly good at insulating the caliper. Constuction of the Cmax pads actually seemed better thermally than the Mintex as the Cmax have a multilayer polymer pad on the back of the pad plate that the Mintex do not.
Just trying to understand where the limits are as there are more than pads in the mix.
+Quote Post
LuckySnake
post Yesterday, 02:47 AM
Post #95
Blayne9067
Group: Members
State or Province:IL
QUOTE (jcthorne @ Nov 19 2009, 04:25 AM) *
The Cmax rear pads have the "noise prevention" pad too. They are a nice improvement.
+Quote Post
enormous
post Yesterday, 05:24 AM
Post #96
Member
Group: Members
So far I am very pleased with the C-max pads front and rear. Great stopping and low dust on the street, all at a reasonable price. I wish I had done this sooner.
+Quote Post
BEEKAY GT500
post Yesterday, 09:48 AM
Post #97
Member
Group: Members
QUOTE (jcthorne @ Nov 18 2009, 05:27 AM) *
i had to try these with all the hype. i 've had them on for about a month now. under normal dirving conditions the rotors were any where from 5*-20* hotter with the cmax pads. i havent checked any temps under hard braking yet.
+Quote Post
6-Speed
post Yesterday, 04:22 PM
Post #98
Group: Members
QUOTE (BEEKAY GT500 @ Nov 19 2009, 10:48 AM) *
Did most of you re-use the factory shims when installing the Cmax brake pads? I know Luckysnake did, but what about everyone else? Did you apply any caliper grease on the back of the pads?
+Quote Post
jcthorne
post Today, 02:07 AM
Post #99
Group: Members
QUOTE (6-Speed @ Nov 19 2009, 06:22 PM) *
The Cmax pads come with new anti-rattle spring clips and have anti squeel pads pre installed on the back of each pad. As the Brembo caliper has no moving slides, there is no caliper grease required.
+Quote Post
LuckySnake
post Today, 03:47 AM
Post #100
Blayne9067
Group: Members
QUOTE (jcthorne @ Nov 20 2009, 04:07 AM) *
The Brembo pads have the anti squeel pads too, as you know. The shim is designed to to prevent early wear of the anti-squeel pad surface, I used the caliper grease between the anti-squeel pad and the stainless shim to also increase anti-squeel pad life. Not using the stainless shim isn't going to make any difference in performance, so either way you are good.
The rear pads could really benefit from the shim because of the "screwing" action of the caliper pistons. This action will wear the pads anti squeel pad.
Bottom line is it doesn't matter if the shim is used or not, other than a little extra wear protection of the ant-squeel pad, but the stock front pads use the shim and the Cmax are the same design, to me it makes sense to use them.
+Quote Post
5 Pages V  « < 3 4 5
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 20th November 2009 - 05:30 PM
