engine chugging and missing
#1
Posted 11 October 2009 - 05:49 PM
The car accelerates fine out of 1st and 2nd with all the power in the world and no missing. 3rd is kind of hit or miss. For the most part, the engine is fine there too, unless I'm going uphill, then I notice it starting to bog. Today, I went up a very large hill on HWY 50 for the first time and I honestly didn't think the car was going to make it. So at an incline, the problem is much, much worse.
Since adding the high flow fuel rails, I never got around to re-installing my fuel pressure gauge sending unit. So tonight, since I'm selling the new rails anyway, I decided to pull them back off and install my OEM rails along with the fuel pressure sender. I checked the injectors for any debris and found none. I checked all of my vacuum lines and they're fine. I do notice, however, that the fuel pressure gauge is jumping around more than I remember it doing in the past. At idle, I'm never above 30psi. At WOT, it's hitting 40psi. What I don't get is that the car seems totally normal out of the hole. As the speed increases and I jam through the gears, the problem presents itself and then gets dramatically worse.
Any suggestion?
Ken
Posted 11 October 2009 - 05:50 PM
Ken
Posted 11 October 2009 - 06:03 PM
Posted 11 October 2009 - 06:11 PM
motorjock205, on Oct 11 2009, 07:03 PM, said:
That doesn't sound good either. However, my issue is non-stop, regardless of temp or other conditions. I hope that was a fluke for your sake!
The more I ponder this deal, the more it seems like the GT500 fuel pumps I installed. If one of those pumps has failed for whatever reason and the other is still limping along, most of this would make sense. However, that still doesn't explain why the car is operating normally through the lower gears.
Posted 11 October 2009 - 06:12 PM
#6
kahmann, on Oct 11 2009, 08:50 PM, said:
Ken
I think you may have a coil or two that went tits up. Could be as simple as plugs.
This post has been edited by LuckySnake: 11 October 2009 - 06:13 PM
#7
Posted 11 October 2009 - 06:16 PM
tekheavy, on Oct 11 2009, 07:12 PM, said:
That's a very good question. But around here anyway, any station running the blend has to advertise it at the pump. So I steer clear of those guys at all costs.
LuckySnake, on Oct 11 2009, 07:12 PM, said:
I'm pulling the plugs now. I'll check back with a report on their condition. Thanks for the input.
Ken
#8
Posted 11 October 2009 - 06:21 PM
This post has been edited by Fontech: 11 October 2009 - 06:22 PM
#9
Posted 11 October 2009 - 06:33 PM
I'm digging for my air compressor nozzle so I can blow the crap out of them, before pulling the plugs.
This brings me to another question. WTH would cause this? Paxton requires the install of a cheesy PCV valve onto the pre-existing vent tube. Would a faulty PCV valve have anything to do with the oil that's collecting here? I've never had a drop of oil in the past. What is the negative effect of removing the PCV valve that Paxton included with my blower kit?
Ken
This post has been edited by kahmann: 11 October 2009 - 06:34 PM
#10
Posted 11 October 2009 - 07:01 PM
I'll get pics in a few.
#11
Posted 11 October 2009 - 07:08 PM
I can't imagine needing two.
#12
Posted 11 October 2009 - 07:16 PM
The Paxton one is to be installed where the original PCV vent tube was installed, from the top of the driver's cam cover into the side of the intake manifold.
However, after pulling the Moroso air/oil separator can I had installed, I noticed that the hose going into the bottom of the can was kinked extremely tightly.
I imagine that this was restricting most if not all of the crankcase pressure. I'm pulling the can for good, till I can figure out a better way to mount it.
For now, though, I have a whole ton of crappy oil mess all over these FRPP zero degree plugs. I'll swap the original OEM plugs back in and hope the coils werent' damaged.
Ken
p.s. These plugs are only 3 months old.
This post has been edited by kahmann: 11 October 2009 - 07:21 PM
#13
Posted 11 October 2009 - 07:30 PM
Is the porcelain chipped or burnt off on that first plug?
This post has been edited by Dans07SGT: 11 October 2009 - 07:31 PM
#14
Posted 11 October 2009 - 07:34 PM
#15
Posted 11 October 2009 - 07:46 PM
Have you tried running a tank of gas without the octane booster? Seems like everybody who's had mis-firing problems has at one time has used octane booster and the plugs are usually orange or rust colored.
Just a shot, maybe back the tune off to run 91 octane.
#16
You guys are way more knowledgeable than I, but wondering about a couple of items:
- how is the oil getting into the coils, then fouling the plugs?
If the collection can kinked hose or a faulty Paxton PVC valve caused excessive crankcase pressure, then might there be damage to seals in the cam covers at each problem coil?
- seams odd that with several plugs fouled that your engine would run Ok in lower gears
Wonder if there is also an issue with inadequate fuel delivery at higher demand, like you mentioned earlier, where the computer may be sensing a lean condition and then significantly retarding the timing which would result in loss of power and poor running
Hate to ask, but have you checked the compression on the cylinders with the known bad plugs?
Hope that there is a reasonable soultion and please keep us posted
Larry
#17
Posted 11 October 2009 - 08:03 PM
Hey Dave, you make a solid point. I'm done with the stuff personally. After seeing what 3 months of using this crap does to the plugs, I'll just leave the timing pulled and stick with 91.
Larry
Hey Larry you make some good points. As for the oil getting to the coils, what I'm assuming is that because of the unreasonably high crankcase pressure, the oil is pushing through the threads, up into the bottom of the coils. The middle and tops of the coils are dry. The seats of the coils are damp with oil. Again, this is just an assumption. As for a compression check, this is the first day I've gotten my hands dirty, so I'm not there yet. Before this, I've been hoping it was something simple - tune, octane, etc, but I'm not so lucky. I hope I don't have to pursue this much further than where I'm at now, but we'll see.
I just finished dinner, so I'm getting back to the plug install now. I've got another bank to tighten down, then I'll fire her up for a spin around the block.
Ken
#18
Posted 11 October 2009 - 08:22 PM
#19
Posted 11 October 2009 - 08:31 PM
blkGT500nCA, on Oct 11 2009, 09:22 PM, said:
I replaced my original filter just a couple months ago, otherwise I'd do it now for sure. Thanks for the input.
I'm headed out on the freeway to put the screws to this thing right now. Wish me luck...
#20
Posted 11 October 2009 - 09:03 PM
No misfiring, no chugging, no hesitation. I was surprised by how much power there was actually. I guess I didn't realize how badly it was neutered over the past month or so. The lack of power kind of crept up on me, enough so that I had it sideways down the freeway on-ramp just now.
Anyway, I ran it without the PCV valve. Instead, I plugged the original vent tube back in. I'll get an email into Paxton to find out how necessary that thing is. Either way, I need to get some spark plugs and probably a set of coils on order, just to be safe.
Thanks again for everyone's input.
Ken
