New 2010 GT500 Steering Wheel - Wiring?!?!?
#1
Posted 20 October 2009 - 12:38 PM
As long as I can get my cruise to work normally, I would go forth with the mod, but I do not want to lose that just for looks and feel of a new wheel.
Any help would be awesome thanks guys.
Posted 20 October 2009 - 12:42 PM
someone already did it, do a google search, its not plug and play for sure, but the wheel goes right on the hub fine enough.
Posted 20 October 2009 - 02:19 PM
Posted 20 October 2009 - 04:04 PM
Posted 20 October 2009 - 06:18 PM
For whatever it's worth, these guys were a big help getting me the right harness to go with the factory sirius satellite module I installed. The harness goes from the Nav unit to the sirius module. Perhaps they can help with the steering wiring?? www.radiosandmore.com
#6
Posted 21 October 2009 - 10:39 AM
'10 Steering Wheel wiring
#7
Posted 22 October 2009 - 10:07 AM
Wow excellent find. Thats exactly what I needed. With that info I feel much better. Hopefully I can do this soon and get some pics up!!
#8
Posted 22 October 2009 - 10:22 AM
#9
Posted 22 October 2009 - 11:49 AM
#10
Posted 22 October 2009 - 02:45 PM
#11
Posted 30 October 2009 - 09:49 AM
#12
Posted 31 October 2009 - 06:20 AM
#13
Posted 31 October 2009 - 06:29 PM
This post has been edited by Shelby-Don: 31 October 2009 - 06:30 PM
#14
Posted 31 October 2009 - 06:34 PM
Shelby-Don, on Oct 31 2009, 10:29 PM, said:
I gotta get that key.......... many times I take my key off that remotething and leave that in my pocket while driving or it hits my knee
Thanks for the reminder
Andrew
#15
Posted 01 November 2009 - 06:41 AM
Shelby-Don, on Oct 31 2009, 07:29 PM, said:
Wow, a Fusion key will work. I'm going ask my dealer when I pick it up for the new stripe job. No key fob would be so cool.
#16
Posted 01 November 2009 - 06:54 AM
Chris
Programming spare keys
You can program your own coded keys to your vehicle. Please read and
understand the entire procedure before you begin.
Tips:
• A maximum of eight keys can be coded to your vehicle.
• Only use Securilock keys.
• You must have two previously programmed coded keys (keys that
already operate your vehicle’s engine) and the new unprogrammed
key(s) readily accessible.
• If no previously programmed coded keys are available, you must take
your vehicle to your dealer to have the spare key(s) programmed.
1. Insert a previously programmed
coded key into the ignition.
2. Turn the ignition from the 1
(OFF/LOCK) position to the 3 (ON)
position. Keep the ignition in the 3
(ON) position for at least one
second, but no more than 10
seconds.
3. Turn the ignition to the 1
(OFF/LOCK) position, and remove
the coded key from the ignition.
4. Within ten seconds of removing the previously programmed coded key,
insert the other previously programmed coded key into the ignition.
5. Turn the ignition from the 1 (OFF/LOCK) position to the 3 (ON)
position. Keep the ignition in the 3 (ON) position for at least one second
but not more than 10 seconds.
6. Turn the ignition to the 1 (OFF/LOCK) position, and remove the
second key from the ignition.
7. Within twenty seconds of removing the previously programmed coded
key, insert the unprogrammed key (new/valet key) into the ignition.
8. Turn the ignition from the 1 (OFF/LOCK) position to the 3 (ON)
position. Keep the ignition in the 3 (ON) position for at least one second.
9. Your new unprogrammed key is now programmed.
If the key has been successfully programmed it will start the vehicle’s
engine and the theft indicator light will illuminate for three seconds and
then go out. If the key was not successfully programmed, it will not start your vehicle’s engine and the theft indicator light will flash on and off
rapidly. If failure repeats, bring your vehicle to your dealer to have the
new key(s) programmed.
To program additional new unprogrammed key(s), repeat this procedure
from Step 1 for each additional key.
Programming Remote transmitters:
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of six)
available before beginning this procedure.
Note: Ensure the brake pedal is not depressed during this sequence.
To reprogram the remote entry transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Cycle eight times rapidly (within 10 seconds) between the 1 (OFF/LOCK) position and 3 (ON).
Note: The eighth turn must end in the 3 (ON) position. The doors will lock, then unlock, to confirm that the programming mode has been activated.
4. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
5. Repeat Step 4 to program each additional remote entry transmitter.
6. Turn the ignition to the 1 (OFF/LOCK) position after you have
finished programming all of the remote entry transmitters. Note: After
20 seconds, you will automatically exit the programming mode. The
been exited.
#18
Posted 01 November 2009 - 02:18 PM
07SGT4578, on Nov 1 2009, 08:54 AM, said:
Chris
Tips:
seconds.
been exited.
Does anyone have the part # for the Fusion Key? Thanks!
#19
Posted 01 November 2009 - 02:53 PM
I believe the part number is: 164-R7013R or 164-R7000
#20
Posted 01 November 2009 - 03:11 PM
Looks like the price has gone up a bit...
http://cgi.ebay.com/...#ht_5901wt_1161
