Best Whipple 550 ET/MPH
#1
Posted 30 October 2009 - 06:38 PM
I ran mine last Sunday, impossible to go to WOT in 1st or 2nd on the stock tires and still managed a 12.5 at 118.4. Couple customers heading to the track again this Sunday and I have to go to tune them so I'm thinking of throwing on a set of my other tires from my EVO since they bolt right up and seeing how quick it will really go.
I'd think with 118 traps speeds 11.7's shouldn't be too tough with some traction and as much as I had to pedal it I'm guessing the MPH is going to go up too, especially with a tad taller tire to avoid that 4th gear shift right at the end of the track.
I just want something to shoot for!
Thanks.
Posted 30 October 2009 - 06:48 PM
Thanks.
THOSE ARE GOOD TIMES FOR NOT HAVING TRACTION. IF YOU DO SOME DRAG
RADIALS YOU SHOULD BE IN THE 11.25 TO 11.60 SPREAD DEPENDING ON YOUR
YOUR TIRE SET UP. B.O.L.
SCOTTY
Posted 31 October 2009 - 09:10 AM
Thanks.
See my sig below.
I had no traction 1st run, and the 116 was a serious lag out of the hole to compensate. I think 120+ very possible on street tires and pressure...
Posted 01 November 2009 - 03:47 PM
I'm certain I'd have dropped the car in the 11's but on my 3rd run I shreaded the blower belt, which means you lose everything, water pump, alternator. Sucks, I had to get a flat bed to take the car home.
Going to speak with Whipple about a better belt, only had about 200 miles on it.
Posted 01 November 2009 - 03:57 PM
If you have the gt500 brakes what tires and wheels are you running with the car...
Thanks for posting.
#6
Posted 01 November 2009 - 05:43 PM
Carry a spare belt and a 1/2 breakerbar with a 3/4 socket it takes 5 minutes to change the belt and can save some good money i shred them every 2k miles or so myself..
#7
Posted 01 November 2009 - 05:45 PM
This post has been edited by 07-2937: 01 November 2009 - 05:46 PM
#8
Posted 01 November 2009 - 06:09 PM
#9
Posted 01 November 2009 - 06:27 PM
#10
Posted 01 November 2009 - 07:09 PM
#11
Posted 01 November 2009 - 07:33 PM
About 3 weeks ago I made about 6 passes with my car. Whipple 3.4, no head work, cams, just a BAP and MAF extender on stock Goodyears aired down to 25 psi.
Best ET of the day was an 11.15@129
Best Trap of the day was 11.24@131
60's for the day were in the 1.8-1.9 range
By the end of the day my belt was pretty chewed up though.
This post has been edited by kaylan1521: 01 November 2009 - 07:38 PM
#12
Posted 01 November 2009 - 07:47 PM
Chris
#13
Posted 02 November 2009 - 04:50 PM
I spoke with Whipple today, they are working on a better belt. I ordered 3 new belts today, I won't get stranded again. I have them sending in 2 day air. Also ordered some tires for the stock wheels. The track might be open again Sunday, going to give it hell.
#15
Posted 02 November 2009 - 06:27 PM
#16
Posted 02 November 2009 - 06:32 PM
Dan
#17
Posted 02 November 2009 - 08:47 PM
Totally bad a** right on thats quick...
on stock tires...great job there!!
You obviously can drive that bad boy!
#18
Posted 02 November 2009 - 08:58 PM
I have experience with HD aftermarket primary belts and they are very very sensitive to alignment. I also know that it is old school biker knowledge that if they heat way up the pulleys (aluminum) "grow" and your belt snaps...
I have snapped exactly one HD primary belt when I was running my bike the hardest I ever ran it. Just to smoke my cousin who was bragging how fast his HD was. It was a very twisty and then deserted road...he took quite awhile to catch up...he went back to his crib got an extra belt and an electric impact wrench and we changed it with the help of an outlet on the porch of a public Lbrary. We towed my HD with his for about 2 miles with rope he also grabbed to get to the Library.
Hemet a drunk girl and went home with her after my bike was put together...Karma
The end result was I never had heated up the primary like that before or since...maybe heat has something to do with the whipple belts snapping as well?
#19
Posted 02 November 2009 - 09:00 PM
Right on!!
#20
Posted 03 November 2009 - 05:15 AM
Lets see some more ET's from the 550HP guys.
This post has been edited by ShowCar: 03 November 2009 - 05:15 AM
