Adding a Whipple....
#1
Posted 04 November 2009 - 07:45 AM
2.9L Whipple (thinking 17lbs boost)
Larger heat exchanger
Boost A Pump
Larger injectors
New MAF
Custom tune
JLT intake
One piece driveshaft
Will I gain much with exhaust changes? Like the stock one.....
What RWHP should be expected @ 17lbs of boost? Has anyone done this yet, and if you did, any recommendations? I don't much like the idea of having to remove the front bumper cover to change the heat exchanger, the paint is perfect and I would like to keep it that way....
Thanks all!
Posted 04 November 2009 - 08:49 AM
Respectfully,
Roger
Boost A Pump
Larger injectors
New MAF
Custom tune
JLT intake
Thanks all!
Posted 04 November 2009 - 09:17 AM
Would love to hear from some of the vendors as to what they would put into a package with the Whipple..probably will just stick to the engine mods as the car will not see the track.
Posted 04 November 2009 - 10:06 AM
Taking the front bumper off to install the heat exchanger is not a big deal at all, and the paint will not be damaged as long as you don't shove and force the front bumper back on. If I remember correctly, there is only like 12 fasteners that hold the complete front fascia onto the car, then unclip the 6 light connections (head lamps, fog lamps, and side markers) and it pulls off rather easily.
Posted 04 November 2009 - 11:03 AM
Boost A Pump
Larger injectors
New MAF
Custom tune
JLT intake
Thanks all!
After making many mods including pulley change, long tube headers and 3" exhaust plus cold air induction and Diablo Tune I decided to purchasr the 2.9 Whipple, larger heat exchanger, boost a pump and aluminum drive shaft. After all was said and done, rwhp went from 517 to 630. I have one last thing I'm going to have done and that is installing the same throttle body that is presently being used on the Cobra Jets. Hopefully this change will add 10-15 hp.
#6
Posted 04 November 2009 - 05:54 PM
Mark
#7
Posted 05 November 2009 - 09:45 AM
If you go this route would love to hear your feedback....on both the pieces and parts and Amazon's work. I know they are recognized for their 03-04 Terminator knowledge but have not seen where a lot of GT500's have gone through their shop...not saying thay haven't just have not heard about them.
Posted 05 November 2009 - 01:18 PM
#9
Posted 29 November 2009 - 09:05 PM
hansonjohn, on Nov 4 2009, 02:03 PM, said:
John, I look forward to seeing your mods at ShelbyFest '10!
Wes
#10
Posted 29 November 2009 - 09:21 PM
65427cobra, on Nov 4 2009, 09:17 AM, said:
LOL, I have to pull off my front clip to FIX the crap ass assembly and paint! The Ford assembly line leaves much to be desired.
#11
Posted 29 November 2009 - 11:15 PM
#12
Posted 30 November 2009 - 07:03 AM
#13
Posted 30 November 2009 - 08:07 AM
#14
Posted 01 December 2009 - 12:37 PM
mullens, on Nov 30 2009, 02:15 AM, said:
Using RTV to seal the blower to the manifold is not really an issue as long as you follow the instructions. Ford Racing puts their name on these blowers and sells them as their kit, so if it were an issue, I don't think they would be doing that.
#15
Posted 01 December 2009 - 02:22 PM
#16
Posted 02 December 2009 - 07:35 AM
So ordered and just finished installing the Shelby Baer extreme plus brake kit....it's purty! Will be driving it this coming weekend to start breaking in the rotors. Needs some regular street miles prior to seasoning the rotors/pads.
Put the silver calipers with blue letters on a grabber blue car. They really look great and the fit/finish is exceptional....
#17
Posted 02 December 2009 - 09:00 AM
mullens, on Dec 1 2009, 05:22 PM, said:
The reason you have to use the RTV is because the countersunk bolt holes that hold the blower plate to the compressor unfortunately cross paths with the stock lower manifold gasket. So the RTV is used to fix that issue. As Derek said if it were an issue FRPP and Shelby wouldn't be selling them.
Jared
