Car Going Into Fail Safe Mode - Why? Anybody Have or Had This Problem?
#1
Posted 04 November 2009 - 06:57 PM
What about the heat soak issues for the SC? Anybody had this problem and what was the solution? Shelby HE?
Just the other day we propped up the hood only to find coolant sprayed over the engine. It came from the cap of the coolant tank. What is causing this issue?
Also, what RWHP are you guys getting with the KB. He has about 425 and he thinks that is too low. KB told him he would get 500. Another disappointment.
Posted 05 November 2009 - 06:48 PM
Your friend has problems....
My '07 SGT had 278 RWHP at the start.....I ended up with 451 RWHP and ~511 HP at the engine. Where do you live? Call KB and ask for the location of a shop that can help your friend. I know there is a SHop NW of Atlanta that is a Beta test site they use. I don't think I would risk the engine to get there. Check your PM
Grady
Posted 05 November 2009 - 06:56 PM
if the fans are not hooked up failsafe will occur
Posted 05 November 2009 - 08:01 PM
Grady
PM checked. He lives in San Jose and has already worked very extensively with KB and drove his car to Sacramento under instruction by KB to work on the car. They got it to work but he isn't happy with the HP, temp issues, and car going into fail safe mode.
Posted 05 November 2009 - 08:03 PM
#6
Posted 05 November 2009 - 08:57 PM
idrathergolf, on Nov 5 2009, 08:03 PM, said:
Which shop in Sac did he see?
Was the coolant from the intercooler reservoir? If so, that's fairly common on the track anyway. When they get real hot and under too much pressure, they 'pop-off' as a safety. Is this happening during normal driving or very heavy throttling?
Ken
#7
Posted 06 November 2009 - 06:09 AM
Ken
Ken,
It squirts out coolant jsut under normal driving conditions. He complains about temperature and 07-2937 commented that the car will go into fail safe when the fans are not connected, so I wonder if the problem is that the fans are not running properly and the car is heating up. Sounds like there can be a connection between the leaking coolant and the fail safe mode.
I don't know the shop in Sacramento but I'll ask him.
Dana
#8
Posted 06 November 2009 - 07:11 AM
Dana
DANA,
I reread the thread, the car is down on HP. The water leak should not be tied into the HP problem, but seperate. Has your friend talked with K Cristy (sp) at KB. Also, I found if you post on the KB section of this site you can expect they read the post especially if there is a problem. I had an issue with the removing the SAI SGT developed program and getting the correct FORD GT program back in the car, before you upload the KB developed program. The car would not run well, but I never had a 'limp back' issue. Again the leak is a separate issue I feel.
Also, I was told by KB that we should not go over 10psi boost as we are at the upper limit at 10 pounds of boost--and limited by the present lower end engine components. Change those parts to forged and you can make more power....but at a cost of engine longevity. The 5.4L SC was made for SC and I seen some 780hp RWHP 5.4s but why in a 3900# car? My SGT/SC will run all over my GT500 (w/ improved suspension) at VIR and those are the roads I drive on. It is not so much the HP as the torque and how it gets it down to the road...ask Porsche?
Grady
#9
Posted 06 November 2009 - 07:06 PM
THE THERMOSTAT NOT OPENING AND THEN CAUSING A
OVERHEATING CONDITION AND FAIL SAFE MODE.
FURTHER MORE I BELIEVE THE THERMOSTAT IS
REPLACED TO A 160 THERMO WHEN RECIEVING THE GT/SC PACKAGE. SO
MAYBE THATS WHERE THE PROBLEM LIES IF IT'S NOT THE COOLING FANS.
SCOTTY
#10
Posted 07 November 2009 - 07:16 AM
SCOTTY
Thanks Scott. By the way, the cooling tanks I bought from you have been installed and working great.
#11
Posted 07 November 2009 - 10:23 AM
