Team Shelby: Oil drain plug torque specs? - Team Shelby
#1 User is offline   gman1920
  • State or Province:NJ
Posted 10 November 2009 - 04:09 PM
I'm new to the forum ( I know, LURKER!!). Just getting ready for my 1st oil change and wanted to know the tightening specs. Anyone with service manual out there? Any specifics about "lessons learned" while changing the oil on the 2010 too or pretty straightforward?
#2 User is offline   Torched10
  • Interests:GTOs,Vettes,Mustangs
  • State or Province:ga
Posted 10 November 2009 - 04:15 PM
dont know the tightening specs,but the filter is on real tight.Thankfully i had one of those filter wrenches that has grabber teeth on the end, otherwise, as someone said on the forum, it takes "2 men and a boy" to get it off. I was lucky enough to use a friends lift, si could could put all if my 6-3 220lbs into it.If youre laying on the floor,good luck
#3 User is offline   AlloyDropTop
  • State or Province:WI
Posted 10 November 2009 - 06:39 PM
Get ready for all the oil to drain all over the filter, your hands, and the cross memebers below it. Otherwise a pretty easy job.
#4 User is offline   tdusseau
  • AntiVenom
  • State or Province:GA
Posted 10 November 2009 - 06:48 PM
I am not sure if anyone here has heard of this but I have used this for years and on my last 5 cars.
It is called "Fumoto Valve" http://www.fumotousa.com
Trust me you will LOVE it. And please don't reply with all the BS about dirt, crud...ect getting in the hole. This is not a valid arguement and like I have said I have used this on my last 5 cars. And YES I have already put one on the new Shelby.
Never again worry about dropping the drain plug into the oil pan, or having to chase it across the floor as it rolls away.
I am in no way tied to this product or company. The Diesel guys I used to run with turned me on to this item, and I have never looked at anothe OE drain plug again.
#5 User is offline   tdusseau
  • AntiVenom
Posted 10 November 2009 - 06:51 PM
Cut yourself a piece of cardboard and fold in into a "V". Place it under the filter, Loosen the oil filter a little at a time, and the oil will drain off the filter onto the cardboard and down into the oil pan.
This makes the process take a few minutes longer, but you will have no oil to wipe off the under side of the car.
#6 User is offline   6-Speed
  • State or Province:AZ
Posted 10 November 2009 - 06:56 PM
Wrench size is 16mm.
This post has been edited by 6-Speed: 10 November 2009 - 07:12 PM
#7 User is offline   6-Speed
Posted 10 November 2009 - 07:10 PM
Like others have mentioned - get a good oil filter wrench like this one.
#8 User is offline   4632R
  • View blog
  • State or Province:oh
Posted 11 November 2009 - 04:33 PM
To answer your question, 20-25 ft. lbs. is sufficient
#9 User is offline   ndsvt
  • State or Province:ky
Posted 11 November 2009 - 07:10 PM
The oil pan drain plug torque spec is 26 Nm (19 ft-lbs)
#10 User is offline   gman1920
Posted 12 November 2009 - 04:22 PM
Thanks. This was exactly the infromation I was looking for.
Any manuals on CD rom posted anywhere yet?
#11 User is offline   shelby001
  • shelby001
  • Interests:65 G.T coupe<br />65 vert<br />68 Shelby G.T 500<br />07`SHelby
Posted 12 November 2009 - 05:34 PM
If you loosen the filter then slip a plastic bag over it then spin it off into the bag (make sure bag has no holes)you will have no mess. Then lub the new filter seal with clean oil spin it on until makes contact & tighten it by turning 3/4 of a turn. Next oil change you won`t need a filter wrench to take it off.
#12 User is offline   6-Speed
Posted 12 November 2009 - 07:03 PM
Since the oil filter is inverted - you can fill it up part way with oil prior to installing it ... should build up oil pressure quicker that way on initial start.
