motorjock205, on Nov 13 2009, 10:30 AM, said:
Well, I ordered the KR Trunk liner a few weeks ago and it finally arrived yesterday, so I decided to mount it this morning. I had heard that there might be a few issues with where the drilling needed to be done in order to miss a few rectangular cut outs in the trunk, so I did a trial fit several times before finally drilling. There are actually four (4) rectangular cutouts in the trunk and you need to be sure to drill right above them in order for the push pins to grab...if you get the pin in the rectangular cutout, it won't hold the liner.
The four places where you need to be careful are the two outside pins in the middle and the two inside pins on the piece near the top.
I know how everyone is about pictures, so here are a few...
Thank you for the suggestions as I was one earlier this summer with concern about one of the holes trying to go into a rectangular hole.
I did a little Persuasion to get the one that was missing the hole to match the other side that appeared good. Once I got the six in the vertical surface around the locking mechanism in, the remaining nine were pretty simple.
I pinned the six and drilled through the holes in the liner - stop device I have for the 1/4" bit is large and very smooth. Drilling slow did not leave marks in the felt. Hardest part with pins in was moving liner enough to paint the holes so I do not get rust.
DrKSGT
