tire pressure monitoring
#1
Posted 14 November 2009 - 11:40 AM
Posted 14 November 2009 - 01:07 PM
Posted 14 November 2009 - 01:10 PM
Posted 14 November 2009 - 02:33 PM
Torched10, on Nov 14 2009, 03:40 PM, said:
An icon lights in the speedo and a written warning shows up in the tach message area. Happened to me last Sun. when I ran over something I did not see, when passing a slow car on the interstate. Put a 3" gash in the left rear tire...sealer of no help. Had to have a tow off the highway and a 100 mile trip, ea way home to get a winter tire that had just arrived from Tire Rack a couple weeks before. I will be keeping one of the spare front tires in the trunk from now on. First flat I ever had on the highway in almost 50 years of driving, and, of course, the first car I ever had without a spare!
BTW, even 2 stacked 4x6 boards under each wheel leading up to the tilt-bed tow truck did not prevent scraping the chin spoiler when loading my 2010 GT500. Fortunately, no visible damage was done.
Posted 14 November 2009 - 03:56 PM
thanks--good idea to have an extra tire at home.have you figured out how to fit the front tire in your trunk.Ive seen Grabber Orange had a good approach,but im not that talenetd mecahincally
#6
Posted 15 November 2009 - 01:50 PM
Torched10, on Nov 14 2009, 07:56 PM, said:
I also saw Grabber's post on that subject, which is great if you have the talent and patience. I will eventually play around with dropping the front tire in the well and probably just lay the soft carpet over it, even though it will stick up a little. I have a box of cleaning supplies, etc. bungied into a corner that will hold the jack and pump, which I might eventually be able to use. If the spare bounces in the well too much, may look into a way to anchor it, but I doubt it will.
#7
Posted 15 November 2009 - 02:21 PM
bring500, on Nov 15 2009, 04:50 PM, said:
Be careful with loose parts in the trunk.I had a jack handle push the quarter out on a GTO once.Dont know if a tire could do that,but if it could itd be ugly
#8
Posted 15 November 2009 - 03:48 PM
Torched10, on Nov 15 2009, 06:21 PM, said:
yep, I've also seen things slide back and forth in the truck and cause damage to the rear panels of the car...gotta be careful.
#9
Posted 16 November 2009 - 08:50 AM
#10
Posted 16 November 2009 - 09:07 AM
bring500, on Nov 15 2009, 02:50 PM, said:
If you're going to keep the inflation kit in the car, why not just let all the air out of the tire so it will lay flat then fill it when you need it? In fact, you can probably stash your supplies under the tire if it's face up.
Just thinkin'.......
Phill Pollard
#11
Posted 16 November 2009 - 09:18 AM
Phill Pollard
well, you need to keep the bead set on the wheel,so taking all the air out wont workPlus im pretty sure its the wheel itself that causes it not to fit in the tire well
#12
Posted 16 November 2009 - 09:26 AM
Torched10, on Nov 16 2009, 10:18 AM, said:
I've busted beads on literally thousands of tires in my life and believe me, that would be the *least* of my worries with a uninflated tire!
If it's the rim width (9 inches for the front?) then you're right, the point is moot. But if it's the two inches of sidewall that protrude out beyond the rim, it would flatten out and save you space.
Phill Pollard
#13
Posted 16 November 2009 - 10:30 AM
Phill Pollard
I checked the one stock front I have in the garage (have winter tires on, now, and the other front is in the trunk) and found the tire sticks out less than 1/4", total, from the rim. Explains why people complain about wheel damage when parking. So letting air out would not help much. But thanks for the suggestion.
This post has been edited by bring500: 16 November 2009 - 10:31 AM
#14
Posted 16 November 2009 - 10:34 AM
bring500, on Nov 16 2009, 11:30 AM, said:
Ya, a quarter inch won't be enough to do squat for ya.
But I had a thought after I posted...what about a jack and tire wrench? Without them, you still have to wait for a tow.
BTW, my car has free towing service included with it. Is that just my dealer or is that a Ford thing?
Posted 16 November 2009 - 11:11 AM
I bought a jack and wrench when I got the winter tires, planning ahead to having a spare. I do have the Ford raadside assistance plan, but a cop kinda pushed me to get going and he gave me the number of a local towing service (probably a relative!) so I did not get a chance to try the free service. Maybe next time...
#16
Posted 21 November 2009 - 04:22 PM
shelby001, on Nov 14 2009, 03:07 PM, said:
The TPMS is a joke!!! The only time mine ever let me know tire pressure was low, was when I was near flat on a rear tire. Now I check all 4 tires at least once a month, and they are always 3-4 lbs below what they should be. Don't trust the TPMS to tell you your pressure is low, check it yourself.
#17
Posted 21 November 2009 - 04:35 PM
Silverghost, on Nov 21 2009, 04:22 PM, said:
Silverghost,
Good recommendation. Many of these Shelby's sit idle for weeks, maybe months. Always best to have the proper pressure before "spirited" driving.
#18
Posted 21 November 2009 - 05:13 PM
#19
Posted 21 November 2009 - 06:08 PM
Silverghost, on Nov 21 2009, 08:22 PM, said:
the tpms won't issue a warning until the tire pressure falls to 25% less than the recommended setting or appox. an 8 psi drop.
This post has been edited by interceptor: 21 November 2009 - 06:11 PM
#20
Posted 21 November 2009 - 06:15 PM
