Team Shelby: Moroso Master Cylinder Brake cover - Team Shelby
#1 User is offline   H0050
  • H0050
  • State or Province:CA
Posted 15 November 2009 - 05:44 PM
Put on a Moroso brake cylinder cover to hide the plastic tank. Fits nicely for a cosmetic look. However, the GTH billet cap will not seal. Anyone else have this issue and what was the fix? I see the standard shelby cap seems to work. I would think they are similar.
This post has been edited by H0050: 15 November 2009 - 05:45 PM
#2 User is offline   SGT/SC2873
  • State or Province:SC
Posted 15 November 2009 - 06:12 PM
check to make sure the cover is all the way down. Mine was a tight fit and once I checked to make sure the slots were clearing the wires, etc. I used a rubber mallet to gently tap it down. Once I did this the cap worked fine. Prior to, there was not enough thread exposed for the cap to tighten down and seal....Craig
#3 User is offline   andrewnagle1964
  • State or Province:NC
Posted 15 November 2009 - 07:25 PM
Same Here
Good Luck
Andrew
#4 User is offline   H0050
  • H0050
Posted 15 November 2009 - 08:32 PM
I thought I had it down all the way, maybe not. I will re-check and try the suggestion.
Thanks. My last and other option is to enlarge the hole just a tiny bit to expose more threads.
#5 User is offline   WildAzCat
  • State or Province:AZ
Posted 16 November 2009 - 04:04 AM
I used a little silicone spray lube on the inside of the cover (or try on tank). Mine went on tight but the custom cap did fit in the end.
This post has been edited by WildAzCat: 16 November 2009 - 04:06 AM
#6 User is offline   stormeaston
Posted 16 November 2009 - 11:48 AM
Mine fit fine also?????
#7 User is offline   H0050
  • H0050
Posted 25 November 2009 - 08:13 PM
Just FYI, my cover seems very snug and will not go down any further. Do not want to force it.
To that end, I solved the fit problem by opening the hole about a 16th or so, cover fit nice, slight downward pressure snaped into place and the GTH billet cap fit nicely. Just in case someone else has a fitment issue.
Have a great Thanksgiving
