816 RWHP 2007 Shelby GT500 VMP 2.3L TVS
59 replies to this topic
#1 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
  • Joined 13-September 06
Posted 04 January 2011 - 08:35 PM
I finally popped one of my new VMP TVS blowers onto my personal 2007 Red/Silver GT500 and got it on my Dynojet 224xLC. I wanted to swap on a new 15% OD Innovators West lower but did not have time.
My car has a VMP TVS with 2.5" upper, CNC port matched VMP high-flow inlet elbow, VMP 72 TB, 123mm maf, 80lb injectors, 1 7/8 Dynatech LTs, and comp stage 2 cams. Bottom end and heads are stock. I'm running C16 but only going to 24deg on the timing.
We're having some coolish Florida weather this week but nothing like the 50* days from a few weeks ago.
I was expecting over 800, just not this far over 800.
http://www.youtube.com/watch?v=3tqn-znNJyg
The little 2.3L TVS keeps on going and going to 6500RPM with no sign of HP or boost drop off. My car is down 2-3psi at high RPM due to the cams, you can see it peaks around 21psi in the mid range and drops off to 18psi up top. I'm not making all this power with brute force and boost like some of the big blowers, but rather airflow and efficiency. When we did the cam swap for the December issue of MM&FF the car picked up around 40rwhp peak when compared to similar conditions. I would expect a car with the VMP TVS and similar mods to mine (lower, TB, LTs, race gas) except the cams to still make high side of 700RWHP.
This graph shows downstream air temp during a loaded dyno pull, there is not more than a 10deg spread.
I can't wait to install the 15% OD lower.
I ran the FRPP TVS for 3 years before having my own TVS manufactured. I'm mainly showing the below graph to demonstrate that the TVS keeps on going when pullied for more more boost (VMP TVS exclusively has 2.5 pulley, FRPP TVS is limited to a 2.6 pulley). The main point is the shape of the graph (it's higher at all points, even above 6k), not necessarily the difference since the FRPP TVS run was done back in the summer when it was very hot.
Justin Starkey Justin@VMPTuning.com VMP Tuning- GT500 Specialists
2007 Shelby GT500 Red/Silver
Highest HP with 2.3L TVS816RWHP/779RWTQ
Mods: VMP 2.3L TVS Supercharger, VMP Dyno-Tune, VMP 2.5" Upper, VMP 72MM TB & Elbow, 123MM MAF, IW 10% OD balancer, 80s, Dynatech 1 7/8" LTs, Comp Stage 2 cams.
New VMP 2.3L TVS Supercharger $3,499
07-12 GT500 Custom Tuning starting at $199
2011 Mustang GT 5.0L with Roushcharger 9.79@140, wife's car
2006 Mustang 4.0L with Vortech @ 15psi & 6spd, wife's car
2006 Jeep GC SRT8 6.1L AWD, wife's truck
2006 F250 6.0L PSD 4WD CC
2000 Mustang Twin Turbo
#2 OFFLINE   dbackg
dbackg
    it's Hammer time
  • 1,185 posts
  • Joined 13-November 07
  • Interests:2008 Super Snake - Black - vert
Posted 04 January 2011 - 08:50 PM
That is simply unbelievable. WOW!
Great job Justin.
Thank you for sharing..
I have one of Justin's tune with a very similar setup. However, I have a vert and I am really limited on the RWHP .... approx 675, due to the
structural integrity and support (lack of) in comparison to a coupe.
He is the KING of the TVS.
SuperSnake. TVS. FRPP CAI. CJ65 TB. VMP *Big TB* Inlet. VMP 2.65 pulley/tune. FORE Billet fuel rails. JLT oil separator. Dynatech exhaust headers. Shelby billet shifter. DYNOTECH 1-piece aluminum drive shaft. 170* thermostat. Shelby Extreme Duty Cooling system. FRPP M-4033-G2 diff girdle cover. 3.73 gears. billet Steeda LCA's & adj UCA. CHE LCA relocations brackets. H&R sway bars. FR3 springs. Tokico D-Specs. Shelby/Fays2 Billet Watts link, Shelby/Baer Big brakes. 20X11.75 rears. Michelin PS2 335/30's.
#3 OFFLINE   Slabo
Slabo
  • 1,942 posts
  • Joined 08-August 08
Posted 04 January 2011 - 08:58 PM
Holy :censored: that is sweet! :salute:
Proud member of Team 40th - 07XL0381
2007 GT500 Vert purchased 8/12/08, #828 of 859 Ebony, Nav, Sirius, assembled on 6/11/07
Reborn 9/14/09 at SAI Vegas - 40th Anniv. package w/ Interior Upgrade, 605HP TVS, 3.73's, Shelby Shifter, Cooling Package and Extreme Brakes.
Many additional mods.
#4 OFFLINE   DarthLord
DarthLord
    Darth Lord
  • 246 posts
  • Joined 30-May 08
  • Interests:GT 500's, Mustangs of all kinds
Posted 04 January 2011 - 09:00 PM
Congrads, Justin. How much does it cost to due the cam change? And can you post some sound clip of the idle? :drool:
#5 OFFLINE   OrthoDude
OrthoDude
  • 59 posts
  • Joined 17-March 08
Posted 04 January 2011 - 09:08 PM
Awesome Justin. I applaud your innovation with your new VMP TVS.
2008 GT500
TVS Supercharger
FRPP CAI
2.65" Upper
66mm TB
Kooks LT Headers w/ catless x
Magnaflow Mufflers
AFCO HE
3.73 Gears
3.5" DSS Aluminum Driveshaft
Steeda LCA's
FRPP Springs
FRPP KR Shifter
VMP 93 Octane
623 RWHP, 610 RWTQ SAE
#6 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 04 January 2011 - 10:47 PM
Wow, nice numbers. Now you need to run it at a track. See what the MPH is at in the 1/4 mile. Last time you said you were making 750 HP. and you ran 130 to 131 MPH. That's the same or less then some guys with Eaton's. I've seen some Eaton's run 135 MPH in the 1/4 mile. Your car is making nice Dyno numbers. Get it out and run it. I'd really like to see some big MPH numbers. It might be time to trade my blower off. You do have cams if i remember right . So I would need cams also, Right ? What stage cams, or are they GT cams ? Did you install complete cam kits or just the cams ? The TVS blowers don't seem to MPH very good. The best I've seen has been like 132 MPH if I remembered correctly. Be careful of the wife's new 5.0. Because it seems to be running really good with that Whipple. You don't wont to get beat by the wife. LOL ...With 800 HP you should be able to run 143 to 145 MPH in the 1/4 mile. With a low 10 second E.T. That's if the car weighs 4000 LB's with you in it. Its probably a little lighter then that. So maybe 146..... :salute:
http://www.competiti...el.com/Phil/bg/
Edited by GT500Tow, 04 January 2011 - 10:57 PM.
1999 ford Lightning 575HP 11.80's [White]
2004 mustang mach 1 Sons car, has 500hp Pro charged, built engine.[White]
2007 Ford GT500, White/blue stripes.
Moser M9 9 inch rear with coilover shocks. All custom built LCA's, UCA, Panhard bar. 3.89 gears DTT. Auto turbo 400 trans is next. Complete custom Leather interior. Lots of billet, complete custom stereo system.
Very proud of our son. Serving in the Navy. On The USS Hampton fast attack sub.
#7 OFFLINE   zombeast
zombeast
  • 293 posts
Posted 05 January 2011 - 02:33 AM
Holy Chit!
I'm assuming you're running an IW 10% O/D balancer?
With your set-up minus the cams, what do you think would be the minimum octane rating required?
What do you think the cams are worth, hp wise?
#8 OFFLINE   Evasive
Evasive
    2008 GT500
  • 514 posts
  • Joined 06-August 08
Posted 05 January 2011 - 03:44 AM
Looks like about 40rwhp for the cams and he is running a 10% (said he didn't have a chance to try the 15% lower)
"When we did the cam swap for the December issue of MM&FF the car picked up around 40rwhp peak when compared to similar conditions. I would expect a car with the VMP TVS and similar mods to mine (lower, TB, LTs, race gas) except the cams to still make high side of 700RWHP."
2008 Alloy Metallic w/Satin Silver Stripes. 650rwhp/630rwtq
2013 TVS
72mm L&M TB
L&M port-matched elbow
JLT 127mm carbon fiber CAI
Custom powdercoated and widened Alcoa's (20x11.75 rear and factory 20x10 front)
Toyo R888 315/30R20 rear tires; Conti DW 275/35ZR20 front tires
Metco idler pulley painted black
C&R heat exchnager
C&R radiator
H&R front/rear sways
FRPP springs
QA1 rear shocks
Griggs Torque Arm
Kenny Brown welded subframe connectors & jacking rails
Steeda adj panhard rod
3.73 gears w/FRPP low profile cover
Shelby SuperSnake JBA 3" manifold back exhaust
bunch of other stuff
Tuned by Jon Lund
Built by Power By The Hour
2008GT500.blogspot.com
#9 OFFLINE   dbowles22
dbowles22
  • 345 posts
  • Joined 13-June 09
Posted 05 January 2011 - 04:17 AM
Thats awesome
Edited by dbowles22, 05 January 2011 - 04:18 AM.
#10 OFFLINE   TN Red Snake
TN Red Snake
  • 188 posts
  • Joined 25-May 10
  • Interests:Fast Toys:
    Harley Davidson Electraglide Classic w/103 Eng
    '09 Shelby GT500
    '09 F-150 Platnium
    18'9" Bumble Bee Bass Boat w/175
Posted 05 January 2011 - 06:55 AM
Whew!!! Justin sets the mark again guys... Almost makes me wish I had waited a while before modding mine so I could have gotten in on Justin's TVS.
Retired Army - Currently Dept of Army Contractor.
'09 Red w/White Stripes GT500
Steeda 114mm Carbon Fiber CAI
Ford Racing KR Strut Tower Brace
Steeda High Capacity H/E
SS Alcoa 20" Wheels w/Nitto 255/35/20 & 285/30/20
Steeda Comp UCA w/HD Mount
Steeda LCA w/Spherical Bearings
Steeda HD Adjustable Panhard Bar w/HD Brace
Eibach S Coil Over Suspension
Shelby Caster/Camber Plates
Shelby short-throw shifter w/Red Stripe Boot
Shelby GT500 Engine Cap Set
JLT Color match Radiator Cover w/stripes
JLT Redline Elite Hoodlift Kit
JLT Shorty Black 8" Antenna
Project 321 Coil Covers (Red)
Polished TVS w/VMP 2.59 pulley w/90mm Idler
Port match L&M Plenum to TVS
IW 10% OD Lower Balancer w/belt
L&M 72mm Throttlebody "Terminator"
Dynatech 1 7/8 LT Headers
PST Carbon Fiber Drive Shaft
Reische 170 T-stat
"The Tank" Intercooler/Radiator Reservoir
JLT Passenger and Driver Side Oil Seperators
Fore FGT Triple Fuel Pumps w/upgraded lines & Fore Black Fuel Rails
Dynatech 3 in catted X-pipe
SVT-1 Mufflers
Justin's kickass VMP Tune
VMP Big TB D-Port Polished Plenum
Steeda LCA Relocation Brackets
BAER 2 piece slotted/grooved big rotors
Ed
#11 OFFLINE   SVTpower
SVTpower
  • 3,078 posts
  • Joined 24-February 06
Posted 05 January 2011 - 07:55 AM
Not all true, Ted from Montreal ran 140 mph on the TVS, full weight car........seen him and his car in my local track in Toronto Motorsports park, the man can drive too. He went to the 2.9 with his 2010 and he's going to remove it this year to try Justins TVS as he posted on SVTp
2007 Shelby GT500 Coupe Ebony/Tungsten stripes Received Dec 27th, 2006
Evolution TVS Stage 5, Car # 11 - 659 rwhp. Officially tagged Sept 16, 2008
TVS Upgrade
Innovators West 4lb lower
Whipple 160mm TB
Evo Heat Exchanger/180 deg.stat
Mafia Extender
Evo Polished Fuel Rails
Ford GT Polished Coil Covers
Moroso Powdered Coated Black Coolant Tank
BMR Billet LCAs, Adj. UCA, Adj. Panhard Bar & Frame Connectors
JLT Carbon Fibre treats
Ford Racing 5GT's Exh., Lowering Springs, 3:73's, Shift knob/handle, & KR strut brace
MRT Hood Lifts
DynoTech Aluminum Driveshaft
Nexuus Gauges with SOS dual pod
Shelby signed Dashplate
Cobra Outlet Plug
'Shorter' Antenna (HomeMod)
Evo/Asanti 20's with 325's & 255's
#12 OFFLINE   SVTpower
SVTpower
  • 3,078 posts
Posted 05 January 2011 - 07:56 AM
Twin Screw what ??? :confused: :slapfight: :happy feet:
TVS Upgrade
Whipple 160mm TB
Mafia Extender
MRT Hood Lifts
Cobra Outlet Plug
#13 OFFLINE   BlackShelby
BlackShelby
  • 659 posts
  • Joined 25-July 06
Posted 05 January 2011 - 09:46 AM
UPR went 136 in street trim including pump gas about a year and a half ago(In the florida heat)
Plenty have been over 140 already I know of and I know at least 4 already which broke the 800rwhp mark including a few with pump gas.(3 I did myself)
With a few things done correctly to the TVS its hard to find a better blower specially one that fits under the hood without modding anything to make it fit.
Yes other blowers can make more power but boost for boost airflow to airflow(CFM) none will beat the TVS power output unless you go with a centrifugal blower or turbo(the TVS design is a pretty efficient blower )
If someone can make 600 plus with a stock Eaton why wouldn't this power be possible with a TVS Eaton? (which is larger in displacement with a superior rotor design over the stock eaton).
Also not doubting that someone cant go 135 with a modded Eaton, but not to likely in street trim will they go that fast. (Skinny slicks weight reduction peferect weather etc yes I can see it) .
A tvs done correctly can , has and is capable of going 140 plus
Cams are worth 20-80hp on these cars with TVS setups depending on the cams used.(At least what I seen already testing a few different ones)
Edited by BlackShelby, 05 January 2011 - 10:12 AM.
#14 OFFLINE   jcthorne
jcthorne
    Member Terlingua Racing Team
  • 1,914 posts
  • Joined 10-January 06
Posted 05 January 2011 - 10:07 AM
Wow Justin.
Absolutely fabulous numbers from a TVS. All your hard work is paying off BIG TIME. I always figured my replacement blower would be a Whipple but not any more. I may never get to 800 but if it can go that far.....Well. Its all the blower I'll need on the street.
Truly amazing numbers and very good curves with lots of torque at lower RPMs.
Gone: GT500 Coupe #3228 Tungsten stripes on Vista Blue
Up next: 2006 Ford GT, Midnight Blue with white stripes.....one day.....
#15 OFFLINE   lawdude
lawdude
  • 1,270 posts
  • Joined 22-December 05
Posted 05 January 2011 - 10:27 AM
That place in the video looks familiar.
2010 Triple Black - Built Motor: Custom Diamond 9.3:1 Pistons, Manley H-Beam, ARP 2000 Head Studs, Rod Bolts & Bearing Bolts, Comp Cams Beehive Valve Springs, CNC Ports, Double Key Crank, Custom IW 10% Lower FRPP: TVS S/C, Ported Plenum, 2.59 Upper, Ken B: Street/RaceTunes L&M: T/B, Cobra Jet: 80# Injectors, Division X: Fuel Rails, KB: B-A-P, Kooks: Headers, Magnaflow: Magnapacks & Resonators, McLeod: RXT Clutch, MGW: Shifter, N2MB: WOT Box, Steeda: Air Intake, Aluminum Drive Shaft, Lower Control Arms, D/S Loop, Motor Mounts, Hood Struts, Adjustable Panhard Bar, Adjustable Rear UCA, 20" Machine Face Spyder Wheels Revan: Heat Exchanger, J&S: Knock Controller
#16 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 05 January 2011 - 11:53 AM
Did anyone tech Ted's car ? JTBH its really hard to believe one guy in the USA and Can is faster with every blower he's ever run. Stock blowers, aftermarket blowers, then everyone else. Cheating is as old as racing. He's not even in the US. If he is really that fast. Then he should call the mags and make it official. Its as easy as a 100 shot.
Ive tested many blowers at the 1/4 mile.. Mostly Eatons. Its easy to ice it on top, around, and inside to get a good time. But if you drive your car to the track with a over spun Eaton. Then its pumping out 350 degree air by the time you get to a track. Enough to fry eggs on your blower. Once your over about 18 LB's then they really start producing extremely hot air. Keene bell did some testing and the TVS was producing 350 degrees at 18.000 RPM's. The nose of this blower wasn't designed to be pushed this hard. So yes anything is possible. But at the end of the day. Its still just an over spun Eaton. Tell them to try this out. Run across town. 30 to 40 mile trip. Then run a 1/4 mile. Let me guess. 131 MPH in the 1/4 mile. Which works out to be 650 HP. Because the PCM pulled timing to stop you from blowing an engine. At 800 you runing on the ragged edge. Not something you want when its your everyday driver. Race car yea it'll work. But if your racing. Get a twin screw.
#17 OFFLINE   69b302
69b302
  • 242 posts
  • Joined 10-January 07
Posted 05 January 2011 - 02:29 PM
134 mph with my TVS. Since most NHRA tracks treat you as a 9.99 car(safety equipment wise) when you go 135 or faster, it is the sweet spot IMO. Twin screw is a better design for max power, but the toque of the TVS and the fact it fits properly make it a good choice for all but the most hardcore racers.
#18 OFFLINE   COBRA SCOTTY
COBRA SCOTTY
    DIRECTOR OF TIMESLIP VERIFICATION
  • 2,231 posts
  • Joined 09-February 08
  • Interests:MAKING MORE HORSEPOWER !!!
    AND
    HOT BINKINI CLAD LADIES IN PICTURES WITH MUSTANGS.
    BUT
    NOT IN THAT ORDER.hee hee
Posted 05 January 2011 - 03:27 PM
Congrats on the awesome numbers and curve Justin. When I move to Florida in a few years I will be retiring at my condo on Vero beach. It sure will be nice to have a place close by to hang out and get my new Stangs In the furture tweaked. :happy feet:
Congrats Again !!!
Scotty :peelout: :peelout: :peelout:
2008 GT500 CONVERTIBLE GRABBER ORANGE / STRIPE DELETE
SCHED DATE 4/7/08
BUILT DATE AAI 4/11/08
DEALERSHIP DELIVERY 4/18/08
UPGRADES PAULS HIGH PERFORMANCE JACKSON MI. 6/17/10
POLISHED FORD RACING TVS , ELBOW WITH 2.6 UPPER ,I/W 10% LOWER ,
123mm POLISHED COBRA JET CAI , 65mm COBRA JET THROTTLE BODY ,
160 DEGREE THERMOSTAT , SHELBY/REVAN RACING HEAT EXCHANGER ,
MAGNAFLOW 3 " HI-FLOW CATTED X-PIPE , MAGNAFLOW 3 " CAT-BACK EXAUST
SCT CUSTOM DYNO TUNE BY PAUL SVINICKI ( 709 RWHP 701 FT-LBS. 110 TUNE / 674 RWHP 663 FT-LBS. 93 TUNE)
PRODUCTION #'S
# 1885 OF # 2070 CONVERTIBLES PRODUCED IN 2008
# 79 OF # 81 G.O. CONVERTIBLES PRODUCED IN '08
1 OF 6 (G.O. STRIPE DELETE CONVERTIBLES BUILT IN '08)
(THE LAST 1 OF THE 6 RAREST GT500'S PRODUCED IN 2008 ACCORDING TO FORD PRODUCTION DOCUMENTS)
2008 SHELBY GT-C/SC GRABBER ORANGE 5 SPEED COUPE
BUILT AAI 6/28/07
BUILT SAI 9/26/07
CSM # 08SGT0123
SAI GT/SC UPGRADES LAS VEGAS 4/13/09
MUSEUM DELIVERY 4/28/09
SAI INSTALLED POLISHED WHIPPLE 550 KIT
SHELBY CENTER GUAGE POD
BAER FRONT BIG BRAKE PACKAGE IN GRABBER ORANGE
ERADISPEED REAR BRAKE UPGRADE
SHELBY FORGED 20" ALCOA'S
SHELBY GT/SC INTERIOR PACKAGE / BLACK WITH (607) SILVER INSERTS
REAR GT SPOILER ; YOU KNOW YOU GOTTA HAVE SOME DOWNFORCE AT 160 PLUS.
( 497 RWHP , 464 FT-LBS. 93 TUNE )
PRODUCTION #'S
SO. CAL. EDITION
( 1 ST ) AUTHORIZED 2008 SHELBY GT-C TO RECIEVE MODS AT SAI.
( 1 ST ) AUTHORIZED 2008 SHELBY GT/SC PRODUCED AT SAI WITH WHIPPLE 550.
( 1 ST ) AUTHORIZED 2008 SHELBY GT-C/SC WITH WHIPPLE 55O IN THE WORLD.
( 1 OF 63 ) 2008 SHELBY GT-C 5 SPEED W/SHAKER 1000 AND IUP , HID , ANTI-THEFT.
( 1 OF 215 ) 2008 SHELBY GT-C COUPES EVER BUILT / ( 211 ) - 5-SPEED'S AND ( 4 ) - AUTOMATIC'S
#19 OFFLINE   vapor08GT500
vapor08GT500
    MMS
  • 3,240 posts
  • Interests:Anything Shelby, Racing, Car Events, People, Building Fast Cars!!
Posted 05 January 2011 - 09:22 PM
Absolutely awesome, as usual, Justin!!!! Absolutly Amazing #'s!!!
Alex
Always Have Several Shelby's, Saleen's, Cobra's and Mustangs For Sale And Will Build To Suit Your Wants/Needs.
Home Of The MMS Mufflers!!!
#20 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
Posted 05 January 2011 - 09:33 PM
The car went 133mph on a warm day back in april/may at Moroso with stock cams and pump gas tune with a little torco (about 20-22* of timing), probably making low 700s. So I should be in the high 130s/low 140s now with good weather, not to mention drag wheels should lighten it up a decent amount compared to the stock 18s with DRs i was running before. It actually weighs closer to 4100lb with me in it. The stock eaton cars that run close to mid 130s are being run on 50-60* nights and have 4.10 gears and full drag wheels. I watch the SAE correction factors on the dyno, and there is a swing of 5-7% from the warmest summer day to a cold night, which adds up to 50rwhp at this level.
Wife's car actually has a TVS too.
My cams have higher lift so the springs were replaced as well.
#21 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
Posted 05 January 2011 - 10:02 PM
I've tested outlet temps on the TVS and screws, and the screws make just as much heat. KB can quote how hot the TVS is, but I have not seen them quote their own blower. We're putting some blowers on an SAE spec blower test stand in MI.
The SCJ had to go with a 4.0L due to heat, Ford engineers weren't happy with the 3.4L's heat output at the end of the run.
Air gets hotter when you compress it, no matter what you compress it with. That is why my setup/car focuses on airflow and not necessarily boost. I am only running 18psi up top with the cams.
I'm not trying to start a screw compressor debate, just stating the facts about the data I've collected and what I have learned over the years.
BTW, this is a milder setup but still running TVS technology. At the 2010 bowling green NMRA race my wife ran her 5.0 back to back in true street with the hood down, MPH repeated as well as ET. This class requires a 30 mile cruise and then 3 runs without opening the hood.
#22 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 06 January 2011 - 12:38 AM
Well I'll tell yea what we can do. Is I'll drive my car over to your track. With my stock blower, stock heads, stock bottom end and race you. With your cams, 800 HP TVS, stock lower pulley. No one can run meth or nitrous. Fats and skinnies are OK. No removing any interior parts or any BS like that. For how ever much money you want. If you don't want money involved. That's OK but i would prefer to race for at least 550. What you charged me for a tune that i had to pay someone to replace and that's being real nice about it. How's next wednesday. Isn't that a test & tune day at your track ? Then we wont have any ifs ands or buts about what your car will run. We can also run 3 back to back runs and see how well the TVS technology does. I'm ready any time you are. I'm calling you out !!!! " Lets get it on" UFC style HAHAHA....Your not afraid of an OLD MAN are you ? I'm going to put a Randy ground and pound on your young A@@...... :slapfight: :hysterical:
#23 OFFLINE   Redline
Redline
  • 254 posts
  • Joined 13-July 07
Posted 06 January 2011 - 12:58 AM
You really should STFO out of his thread with your usual bullshit. He is a paying advertiser and you're coming into HIS thread, bashing HIS results.
EDITED - Not my place.....
GT500Tow -PM'd you to keep his thread clean. :censored:
Edited by Redline, 06 January 2011 - 01:15 AM.
2007 Shelby GT500 | Black w/Red Stripe Package, | #25 of 169
#24 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 06 January 2011 - 01:20 AM
EDITED - Not my place..... GT500Tow - Why not call ME out OLD MAN? Come to MY track, race ME for $5000?
Looking at the way your typing. I don't believe your in any condition to race. HAHAHA. But later on if you still want to. I'll take you up on it. We can dial the cars in. Then race for consistency or bracket race. Best out of three, "anytime you want" You called out me. So you have to come to my track. I'm ready. Its ether put up or shut up.
#25 OFFLINE   Redline
Redline
  • 254 posts
  • Joined 13-July 07
Posted 06 January 2011 - 01:33 AM
Actually, YOU called ME out ......3 years ago on youtube:
Notice I then challenged YOU to come to MY track, for $5000... You never responded. :hysterical3:
You then called out Ted Lewchuk saying he is "cheating" or spraying 100 shot in order to run 140mph with a TVS.
Now you call out Justin. I am sick and tired of you talking smack about good people on these forums.
By the way, I don't race for consistency or bracket race. I will race you heads up, pro tree, whoever gets to the end first wins. You know, a real race. :shift:
Let's take it to PM's if you want to get this on. I will gladly take your money. You're right, it's put up or shut up! :talkhand:
#26 OFFLINE   lawdude
lawdude
  • 1,270 posts
Posted 06 January 2011 - 02:24 AM
I'll be glad to race GT500TOW too. I'm willing to put up a dollar ninety eight.
#27 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 06 January 2011 - 05:17 AM
Its easy to get behind a key broad and run your mouth. Ive never called anyone out. Justin is the first. I call BS when i see it. So like i said. You called me out. Come and get yea some. You want heads up. That's fine. I'll be spraying just like you do. Bring it anytime. My home track is BMSP. Look it up one line and make a date. Best out of three for 5K...............Its UP........... LAWDUDE. Your not worth racing.
#28 OFFLINE   Evasive
Evasive
    2008 GT500
  • 514 posts
Posted 06 January 2011 - 05:34 AM
Playing Devils Advocate, you made a pretty big accusation about Ted being a cheat with zero to back it up. That's a pretty weak thing to do.
Edited by Evasive, 06 January 2011 - 05:45 AM.
2013 TVS
72mm L&M TB
C&R heat exchnager
C&R radiator
FRPP springs
QA1 rear shocks
Griggs Torque Arm
Tuned by Jon Lund
#29 OFFLINE   GT500Tow
GT500Tow
  • Members E
  • 2,624 posts
  • Joined 10-July 07
Posted 06 January 2011 - 05:46 AM
Playing Devils Advocate, you made a pretty big accusation running your mouth about Ted being a cheat with zero to back it up. That's a pretty weak thing to do.
Where did you get zero ? I have experience and i call it like i see it. He could of proved it. He never did. That would of been the easiest way. Right ? If someone would of called BS on one of my runs. That's what i would done. But he didn't. :jackinbox:
#30 OFFLINE   Seahorse
Seahorse
  • 402 posts
  • Joined 15-March 06
2009 Shelby GT500 Convertible - Ebony/Red /White
11.42 at 124.37
