PonyPack
Grill Fitment with CS6 Front Fascia
I currently own a 2006 v6 Mustang with a Pony Pack and would like to install the CS6 front fascia. I would like to keep the stock grill and foglights and wanted to know if this was possible. I called Shelby a few times and never found anyone that could help and was finally told to just ask here. If you know of any way to install the front fascia with the stock grill or modify the grill to make it fit, I would greatly appreciate it. I know you have to use the CS6 grill with the GT, but as mine is the v6 and the grill housing is the same, I cannot see why I need something else. Any help on this would be greatly appreciated.
Edited by PonyPack
I think it will work ,if you use the stock V6 grill in the CS6 front fascia ,,grill should be the same size across the opening ,,so I would say yes it will work ,,and a GT grill is a different size , than the V6 one , GT grill is bigger / longer across the opening ,, you " can not " put a GT / V8 grill in the CS6 front fascia ,want work ,to big ,, hope this helps alittle ,, I've been there ,done that ,, just saying , :camera: ,002410-R1-22-3A.jpg,,,Respectfully Richard . B)
The CS6 fascia will most certainly work with the stock grill as that is what is used in the CS6 grill assembly.
You have to take the stock grill and cut out the center then fit the CS6 grill with threaded rod and nuts so the main framework in the original V6 grill itself.
The CS6 grill is just an overlay that bolts to the factory grill.
