Hello, I have a 2006 GT-H with 10k miles on it. It is an automatic but when I shift it manually 1st - 3rd I am experiencing some troubles. In first gear I can climb to desired RPM then shift and it will let me do the same in second gear. So no problems in first and second gear, however when I shift it into third gear the car will automatically shift at 2500 RPM. The car will not let the RPMs climb past 2500, it will shift automatically on its own (only happens in third). It hasnt thrown any codes and the dealer said that it is an automatic and should be driven in auto. Also if it matters it shifts as it should in drive???? Any information would be greatly appreciated.
Hummmm... not sure about automatics, most of us have manuals in GT350s, maybe you should try posting this in the GT-H section of the forum instead of the GT350.
