So I finally made it to Pro-Dyno today; thanks to Craig G aka SGT/SC2873 for the recommendation.
2 hour drive to Charlotte, went down last night and had a 8 am appointment this morning
Dan DeSio owner and operator of Pro-Dyno is just an awesome guy and knows his stuff. $375 out the door and we were there 6 hours. ( We had issues with the Nitrous bottle getting warm, it was 37 degrees outside. We never got enough bottle pressure to use the nitrous, so I will need to go back in the summer for the nitrous tune, this dyno is Naturally Aspirated)
Final numbers are 356 RWHP 331 Torque NA
Edited by andrewnagle1964
I meant rpm wise, but I suppose that will simply be when the 125 shot flat lines.... I'd be stoked with those numbers too though, pretty sweet!
I should have actually read your question instead of blindly typing my answer. Not sure what you are asking but the nitrous will kick in at 3500 rpms and i will probably still shift at 6500. If that is what you meant. Hope you have been doing well.
Andrew
Nice numbers.
What kind of exhaust are you running?
American Racing Long Tube Headers 1 3/4” Hi-Flow cats and X pipe
with FRPP Axle Back Mufflers “Stingers”M-5330-5GT
Yeah, just meant what your shift point was planned on being... I don't know what kind of rpms the heads and aluminator will support, but figured with the nitrous you could peak a little higher maybe....
Things are good, just gotta make time to put the '68 back together for summer fun!
Congrats! You did it!
What other mods are you running?
07SGT4623
Custom Tuned by Dan Desio Pro-Dyno
AB Emblem Custom Dye Sublimated Visor Cover
Afco High Performance Aluminum Radiator 4”
Agent 47 Retro Side Mirrors
Amsoil Air Induction Filter EAAU6075-EA
ARP Flywheel Bolts
ARP Head Bolts
ARP Crank Pulley Bolt
ATE Super Blue DOT 4 Racing Brake Fluid
Auto Meter Cobalt Nitrous Pressure Gauge
Auto Meter Cobalt Oil Pressure, Fuel Pressure and Water Temp Gauges
Auto Meter Cobalt A/F Wideband Gauge
BMR Tubular K-Member (KM011)
BMR Tubular A-Arms (AA019)
BMR A-Arm Support Bar (AAS001)
BMR Radiator Support (RS003)
BMR Z-Brace (CB0004)
BMR Panhard Bar Support (PHR007)
BMR Drive Shaft Safety Loop (DSL010)
Bob’s Auto Mustang KR Axel Reservoir
Bosch 39lb Fuel Injectors
Canton Coolant Expansion Tank
Chip Beck Functional Hood Scoop
Continental Extreme Contact DW Tires 275/40R18
DriveShaftShop One piece Aluminum Drive Shaft
Exedy Mach500 Clutch
Exedy 8-bolt Steel Flywheel
FF Dynamics Slim Fan and Aluminum Shroud
FordFan FRPP Tow Hook and Custom Bracket
Fore Precision High Flow Fuel Rails Black Billet Aluminum
Grabber Pony Custom Shift Knob
Hurst Short Throw Shifter
Innovators West Harmonized Balancer
J&M Adjustable Upper Control Arm
J&M Lower Control Arms with Relocation Brackets
JPC Stainless Steel Racing Clutch line
JTL Oil Catch Can
Kenne Bell Boost-a-Pump 40 Amp
Kenny Brown Jacking Rails
Koni Yellow Adjustable Struts and Shocks
Lethal 180 degree Thermostat
Luminar 32% Black Window Tint
Maximum Motorsports Adjustable Caster Camber Plates
McGard Black Locking Lug Nuts
Meziere Electric Water Pump
Midwest Auto Painted Radiator Cover with Extensions
Moroso Power Steering Fluid Reservoir
Moroso Deep Sump Modular Oil Pan
Optima RedTop® High-Performance AGM Battery
PA Performance 6G Alternator 130 AMP Powder Coated White
PIAA Sport Horns 115db 400HZ +500HZ
PIAA Xtreme White Plus Bulb H13
PIAA 5192 Driving Lights
PIAA Super Sporza Silicone Wipers
POR15 Rust Treated and Painted Rear End
Redline Elite Hood & Trunk Lid Struts
Red Line 5W20 synthetic oil
Roush Vent Gauge Pod
SafeCraft Fire Suppression System LT10
Samco Silicone Coolant Hoses
Shelby GT500KR Trunk Liner
Shelby Billet Engine Caps
Shelby Billet Under Hood Hardware
Shelby Billet Black Hood Pins
Shelby Billet Pedal Covers & Dead Pedal
Shelby Berg Snake Faux Gas Cap
Shelby Satin Chrome Quarter Light Trim
Shelby Brake Cooling Kit
Shelby Billet Black Grill Assembly Upper & Lower
Shelby Carpeted Floor mats
Shelby Grille Pony Emblem
S&H Performance Oil Filter Relocation
SHR Tru-Billet Fuel Door Black Anodized
SHR Tru-Billet Lock Pocket Set and Door Pins
SHR Tru-Billet Window Sill Plate
SHR Tru-Billet Side Mirror Knob Black Anodized
SHR Tru-Billet Power Point Plug Black Anodized
SHR Quarter Window Louvers Painted Black
SHR Trunk Release Button
Speed of Sound Cup Holder Gauge/Switch Panel
Speed of Sound Triple Dash Gauge Pod
SS Inserts Air Brushed Fuse Box Cover
Stage 8 Locking Header Bolts
StangMods Clear Rear Side Marker Lenses w/ Red LED Bulbs
StangMods Clear Turn Signal Lens w/ Stealth Bulbs
Steeda Bumpsteer kit
Steeda Front Street End Link Kit
Steeda Carbon Fiber Intake Elbow
Thump RRR Belt Tensioner and idler pulleys
TSS Billet Gear Oil Pump
UPR Shorty Antenna
UMI Double Adjustable ChroMoly Panhard Bar (Rod Ends)
Vogtland Lowering Sport Springs
Web Electric Sequential Tail Lights
Wilwood Superlite 6R Big Brake Front Brake Kit (Hat) & Superlite 4R Big Brake Rear Parking Brake Kit, 13” Rotors Drilled and Slotted and Stainless Steel Brake Lines
Zex Nitrous System, Heater, Remote Bottle Opener, Blow Down Tube, Purge, Window Switch
Painted on Stripes Satin Silver Paint code is M7049A Sherwin Williams #63454 SHELBY GT lettering is Myriad Pro Bold Italic 163 pt.
Kicker Shelby Premium Audio System, 6x8" Speakers, 8" Door Mounted Woofers, 4.1 Channel Amplifier & 10" Subwoofer
Ford Racing Performance Parts
M-6009-A463 Aluminator Forged Internals 9.8:1 compression ratio
M-9424-463V Intake Manifold
M-6050-463P CNC Heads
M-6550-3V Hot Rod High Lift Cams
M-9926-3V Throttle Body
M-6582-3VBLK Black Valve Covers
M-4209-G410 4.10 Gears
M-12405-3V12 0 degree Spark plugs
M-5570-A Jounce Bump Stop Kit
M-4033-G2 Axle Girdle Cover
M-1007-S1895B1 Black SVT Wheel With Machined Lip
M-1096-FR Ford Racing Center Caps
M-5330-5GT Axle Back Mufflers “Stingers”
M-20201-S197 Strut Tower Brace
M-5490-A Sway Bars and Anti-Roll Bars
M6731FL1A Racing Oil Filter
Jesus. I think you left out the fuzzy dice hanging from the rear view! Just kidding. Great list of mods! Make sure you update us when the nitrous is connected and tuned. I was looking to put that same kit on mine.
That's Awesome!!!!!!!!!!!!!!!
Edited by 07SGTC
Dan and all the guys at Pro-Dyno are awesome and they do GREAT work (check out their web page for all the services they provide) I highly recommend them to everyone! This is my local shop and I have had them do all of my mods and tuning. Well worth the drive for people out of state... you won't be disappointed!!!
I did forget the most important mod
Escort 9500xi !!!!!
