TXSGT
Cs8 Grille.
Does anyone have any pictures of a white SGT with the CS6/CS8 grille with the Shelby letters?
http://www.shelbystore.com/Upper-grille-insert-for-Shelby-CS6-and-Shelby-Terl-p/cs6-009.htm
My grille is starting to show it's age, and I'm on the fence about getting this CS8 grille, but I can't find any pictures of a white SGT with one anywhere! Surely mine couldn't (potentially) be the only one in existence! Please post pics if you have them!
Also, is this grille a direct fit with my SGT, or will this require further modifiction?
I trimmed my grill shell a little when I installed mine but I bought the grill shell that the Shelby store sells a little while back because my shell was looking like a roller coaster along the bottom! The shell from Shelby is the one they used on the 08s and is much better and stronger than the cut up original......
Edited by 15modracer
Mine required zero modification. I popped old honeycomb with billet overlay out, and snapped new cs8 grill right in. Took a whole 10 mins total.
Awesome! Thank you so much for your pictures and replies!
Also, I was under the impression that the ones currently for sale no longer use the lights, is this correct?
What are you guys doing with your lower grilles? I don't seem to see any that match available online.
I was under the same impression but when mine showed up it had the light holes!! I blanked mine until I decide whether I want to put the lights in....
I thought the one on sale only fit the V6/CS6/CS8/Terlingua fascia?
Edited by EL SHELBY
??? ,,, will the one for sale now ,fit the GT front bumper hole ? ,,, more info please Jer , :) ,,
One of the 1st mods I did.
What is that hood you have on the White/Blue one?
there were lower grilles that matched but if you had the intercooler it interfered with the lower lights so you could only use the cooling ducts. I think it would have fit but SAI was too lazy to make changes
Are the grill letters available through SPP. If so which set?
That would be my guess. I think backing plates are need for installation.
the one that is listed at SPP is for cs/terlingua front bumper fascia. will NOT interchange to GT or CS front fascia.
They look like the letters that go on the trunk lid but not positive.
The letters are different than the stick on ones for rear trunk lid. The grille letters are pin on and require a backing plate.
Also, for you guys whom are wanting these, PIAA has discontinued the lights needed for the grille. You may be able to find some out there, or find one that will fit, maybe.
For those that care, PIAA does make a smaller oval style light that does fit. Ive had both the CS8 and CS6 grilles in my hands and measured to verify. It was an obscure part number, and I had to email PIAA directly.
