  • Announcements
    • Staff
      ABOUT TEAM SHELBY   01/01/2007
          Member Benefits:   First, there's the Team Shelby swag. No other club packs your membership kit with more than Team Shelby! Whether you are a renewing member or new to the “family” of Shelby enthusiast worldwide, our goal is to help you enjoy a high-octane lifestyle!   From a Unique Membership Card, Team Shelby Calendar, Team Shelby Hat, Team Shelby T-Shirt, Windshield Cling, Team Shelby License Plate, and Lapel Pin -  the contents of your Team Shelby Membership Kit more than pay for your membership alone!   In addition, your membership includes:   Exclusive Access to Team Shelby Member Forums   10% discounts at Carroll Shelby's Stores in Las Vegas and Los Angeles (present current member card for discount)   Driving Experiences   Invitations to Exclusive Team Shelby Member Events   Insider information from Shelby American   Affiliate Partner Discounts   Updated January 2, 2019. Team Shelby Club 2019 Team Shelby Membership Kit Please note that membership contents are subject to change.   Team Shelby was designed and engineered by real enthusiasts inside and out of Shelby.   Team Shelby was originally formed in 2008 by Carroll Shelby. He wanted to create a club for people to truly enjoy their cars. He knew the world had changed, and he wanted his companies to meet the needs of the new generation of Shelby owners. His vision was to knit together those people with the owners of early Shelby's and give everyone fun new ways to experience their high performance vehicles.   Mr. Shelby imagined a place where owners could talk about their latest conquests at the track, swap stories, share photos and learn new ways to hot rod their cars! He wanted to link all of the enthusiasts into one "dream garage"... thus, Team Shelby was born!   Team Shelby has many free, open access forums, news sections and member only areas dedicated to the community.   In addition, Team Shelby has a full series of events for 2019, which include VIP Experiences, track days, National & Regional gatherings, cruises, car shows and more! Ownership of a Shelby is not required to be a member. The club is dedicated to serving all Shelby enthusiasts past and present including those that own cars built in the 1960's and Shelby Dodges too! Carroll Shelby (Team Shelby Member #001) said: "We built Team Shelby for anyone who is passionate about Shelby cars! We’ll have a blast and we'll do it the Shelby way!   Yearly Membership Rates   U.S. $49.99 | Canada & Mexico $59.99 | E.U., others $65.99   Join the Team Shelby Club   click here to choose a Team Shelby Club subscription package.   Membership Kit Arrival   Your Team Shelby Club membership kit and I.D.card will generally arrive within 6-8 weeks.   Need Help?   Email Brianna:  e-mail her here.
    • ForumAdmin
      Having Problems Logging In To Team Shelby ?   02/12/2018
      If you are having a problem logging in to Team Shelby since the software change made last December/January please send an email to bfawn@shelby.com  Please include your real name and Team Shelby user id in this email so that we may look into what the problem might be. Thank you.
    • ForumAdmin
      * * * 2019 TS VEGAS BASH TICKETS AVAILABLE * * *   01/24/2019
      2019 Bash Tickets
that__seth__guy
Alternator/voltage Regulator Inquiry....
Hey guys (and any gals),
I have a 1971 Ford 302 in my 1968 Mustang (for background information), I have replaced ALL ignition components with MSD products. I have also put in a nice Retro-Sound stereo and LED tail lights along with upgraded headlights... my question IS: At idle, my battery voltage is 12.6v and with all lights on its 12.3v... is that too low? When I rev the engine above say 1,700RPM it comes up to 13v but at idle and in gear, its the 12.3v. I've had the battery tested, it holds charge. Should I replace the alternator with a higher output to compensate my MSD setup??? New Voltage regulator? Both?
ANY input is requested and GREATLY appreciated!!!!
-Thanks!
My son's 71 had a simular problem and after checking everything out we found a corroded ground between engine block and body, corroded wiring harness coming from the alternator.
We had already had the alternator tested and found out it had a bad diode so it and the voltage regulator were replaced which helped but output was below normal until the ground and
harness connections were cleaned. After that we had 12.9 at idle and up to 13.9 above idle. The repairs also eliminated most of the flickering of the lights even with the mechanical regulator.
Same issue with late model classics here. Check all grounds for dirt, oil, corrosion and wire brush them clean. Also, the MSD unit doesn't like hot engine compartments and is more stable if relocated under the dash. If you upgraded your stereo, starter, fuel pump or any other electrical demands, you will need a stronger alternator. Going up a few amps always helps as the factory unit is pretty low on output. Also, what is your idle setting? You could go up 50 to 100 RPM if needed, especially if you upgraded the carb and intake.
Thanks for the quick replies! I checked all grounds and decided to clean everything and check for wire breaks first. After that didn't solve my problem, I took out the alternator and took the back off. One of my brass connections was off and actually being ground down... Went and picked up a new alternator for like $40 and that fixed the problem! Im happily idling at 13.4V! Even with every light on (including both turn signals) and the radio blaring, it idled at 12.8-12.9V!!! Problem solved!
Edited by that__seth__guy
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
