08SGT1234
New Wheels And Tires.....
Well I gave up on my hunt for a set of Hyper Silver CS56s, so I went with American Racing......
18x9's with BFG g-force Comp 2 255/45's on all four corners.
Edited by 08SGT1234
I like it, great choice.
Yes, they do. When I was researching similar wheels I thought I learned that those AR wheels didn't have the proper backspacing for our cars??? Do they stick out past the fenders? Can you clear Brenbo brakes? I see you are running a conservative 255 tire. Is that all you could fit without rubbing? Again, they look GREAT!!! Similar to the CS69 a bit..
Troy
Yes, they do.
Yes the do, they have 45mm, 35mm & 24mm (the stock wheels are 50mm) I went with the 45mm. They also come in 18x9 20x9 Chrome, Gray powder coated and Machine/Black.
No, plus I installed an adjustable panhard bar last weekend, my rear end was off 3/8" towards the driver side, now its perfectly centered.
I don't believe so, selecting the GT500 on their fitment guide was not listed.
My goal was to have a tire that was a little wider but close to the original size so not to throw the speedometer off too much, I believe some have run 275s on all four corners with a 9.5" wheel. That combo was a little too pricy for me.
I also chose to go in this direction so I could at least rotate the tires front to back every 3k mile. I'll be installing camber bolts and getting it aligned next weekend.
Thanks! And yes, very similar but much more expensive.....
Troy
Need new tires,so I thought I'd change from stock to these. SGT mostly stock,any pros or cons and advice on other tIres is appreciated.
STAGGERED SHELBY RAZOR CHROME WHEEL & NITTO INVO TIRE KIT - 18X9/10 (05-14 GT, V6)
Staggered Shelby Razor Chrome Wheel & NITTO INVO Tire Kit - 18x9/10 (05-14 GT, V6)
$1,959.99
http://s7d4.scene7.com/is/image/Turn5/33385?$enlarged810x608$
WOW!!! Old School! I love those on your car Troy! :rockon:
Troy?
Whoops..... sorry. I saw "Troy" at the bottom of the above text... Didn't get the quoted text very well.
I'm old...and a dumb ass, but I still Love your wheels!! :lol:
Just messin' with you..... :poke:
Thanks. :hat_tip:
Yes, they do.
Troy
I'm running 275/40/18 on a 9.5 wheel at all four corners but that tire size will fit a 9in wheel.
Your setup looks slick!
Thank you....
At the time I was looking for the best bang for the buck, I spent around $1700 for everything (wheels, tires, panhard bar, camber bolts and alignment).
Maybe I'll look at the 275 set up for the next set. It's going to be a looooooooooong time, I've logged less than 3k miles since installing them nearly 2 years ago.
Those look awesome ... Great upgrade.
Thanks.... :hat_tip:
