Removed rear seats, etc.... to continue my DynaMat project (trunk is done)
Not sure where on the parcel shelf to put the Dynamat on the top (inside of cabin) or the bottom ( inside of trunk)
I will also be removing the kiddy seat tie downs and cutting holes to make rear cabin sub woofer vents
Cant' decide to come at it from above or below, grind or drill
From the picture it looks like it is just spot welded? If so why not just drill out the spot welds then can pry it right out maybe.
I used a similar material in my trunk and above wheel wells and under the rear seating area....made a world of difference. FYI for the most part this stuff does not work by blocking out sound so it does not really need to be perfectly butted together and taped. It actually works by dampening sound by adding weight to the thin sheet metal, that otherwise acts like the skin of a drum.
What he said.
In one of my many lives (LOL), I worked at a recording studio design firm. We designed some of the world's best rooms.
Dynamat is for resonance reduction, as stated above. Concentrate it close to the speakers or sources of noise generation (UCA mount, above the diff, etc…). Some people install 12-18" squares with the 6X8 speaker hole cut in it, so the speaker is mounted through it. It helps reduce rattles, especially in the door locations.
For "blocking" sound, Auralex SheetBlok (basically a roll of heavily-leaded rubber or vinyl) is used. But the rule is, "If it isn't watertight, you've just wasted your time". Lots of small studios spend a fortune on the stuff, then forget the electrical outlets, HVAC vents, etc. Cash down the drain.
As for "subwoofer vents": The sub box itself is designed to be either a bass reflex or acoustic suspension device, no venting is needed or beneficial.
Flashbacks from a couple of months ago... :hysterical:
You'll notice the difference when done. I ended up using 61 sheets for my car, but used Hushmat instead.
Dan
and when you install this stuff....wear gloves and be prepared for how sharp the cut pieces are......uggghhhhhh sliced hands suck
That's the best part about Hushmat, it doesn't cut your hands and is easy to install. No roller needed either, I just used a micro fiber rag to work the sheets down into place.
Dan
Kiddy tie down cover gone
got tired of not being able to play music from my iphone, so since i had the back apart bought the USA-Spec interface, works great used the RCA out puts since I have a iphone 5 and the cable is for a 4 and did not want to spend $30 on an adapter
plugs into between the Sirius controller in the trunk and the radio and have enough cable to put the control unit under the front seat
More Dynamat
Lifesaver torx wrench
Will using these products on the rear trunk and between the struts help to quite the road noise. Rick Gardner
FYI they make a drill bit designed just for spot weld removal.
Correct I got a cheap one at harbor freight since I only had 8 to do worked great (see post #5)
Would have spent more but couldn't find a USA made one locally on a Saturday.
Andrew how did the dynamat project turn out? Just did my trunk and drivers side door. Waiting for the rain to clear so I can turn the car around and do the passenger door.
