  • Announcements
    • Staff
      ABOUT TEAM SHELBY   01/01/2007
          Member Benefits:   First, there's the Team Shelby swag. No other club packs your membership kit with more than Team Shelby! Whether you are a renewing member or new to the “family” of Shelby enthusiast worldwide, our goal is to help you enjoy a high-octane lifestyle!   From a Unique Membership Card, Team Shelby Calendar, Team Shelby Hat, Team Shelby T-Shirt, Windshield Cling, Team Shelby License Plate, and Lapel Pin -  the contents of your Team Shelby Membership Kit more than pay for your membership alone!   In addition, your membership includes:   Exclusive Access to Team Shelby Member Forums   10% discounts at Carroll Shelby's Stores in Las Vegas and Los Angeles (present current member card for discount)   Driving Experiences   Invitations to Exclusive Team Shelby Member Events   Insider information from Shelby American   Affiliate Partner Discounts   Updated January 2, 2019. Team Shelby Club 2019 Team Shelby Membership Kit Please note that membership contents are subject to change.   Team Shelby was designed and engineered by real enthusiasts inside and out of Shelby.   Team Shelby was originally formed in 2008 by Carroll Shelby. He wanted to create a club for people to truly enjoy their cars. He knew the world had changed, and he wanted his companies to meet the needs of the new generation of Shelby owners. His vision was to knit together those people with the owners of early Shelby's and give everyone fun new ways to experience their high performance vehicles.   Mr. Shelby imagined a place where owners could talk about their latest conquests at the track, swap stories, share photos and learn new ways to hot rod their cars! He wanted to link all of the enthusiasts into one "dream garage"... thus, Team Shelby was born!   Team Shelby has many free, open access forums, news sections and member only areas dedicated to the community.   In addition, Team Shelby has a full series of events for 2019, which include VIP Experiences, track days, National & Regional gatherings, cruises, car shows and more! Ownership of a Shelby is not required to be a member. The club is dedicated to serving all Shelby enthusiasts past and present including those that own cars built in the 1960's and Shelby Dodges too! Carroll Shelby (Team Shelby Member #001) said: "We built Team Shelby for anyone who is passionate about Shelby cars! We’ll have a blast and we'll do it the Shelby way!   Yearly Membership Rates   U.S. $49.99 | Canada & Mexico $59.99 | E.U., others $65.99   Join the Team Shelby Club   click here to choose a Team Shelby Club subscription package.   Membership Kit Arrival   Your Team Shelby Club membership kit and I.D.card will generally arrive within 6-8 weeks.   Need Help?   Email Brianna:  e-mail her here.
    • ForumAdmin
      Having Problems Logging In To Team Shelby ?   02/12/2018
      If you are having a problem logging in to Team Shelby since the software change made last December/January please send an email to bfawn@shelby.com  Please include your real name and Team Shelby user id in this email so that we may look into what the problem might be. Thank you.
nsstang
High Revving Engine
Just wondering if anyone out there is having an issue with their car not idling down when coming to a stop. Different times it's continues to rev around 2000 - 2300. Giving it a quick shot does not help. Any ideas what causes this?
Sounds like a tuning issue. I would re-flash the tune and if that doesn't work datalog and send file to your tuner so he can see the trims.
this seems to be pretty common from my experience, both with the FRPP tune and now my current Jon Lund tune, but at more like 1,200 RPMs (until completely stopped). it used to happen at a higher RPM on my 2006 Mustang GT, like you are describing, but it resolved itself when i switched from a canned DiabloSport tune to the FRPP tune. hope that helps.
Edited by 2007tungstenGT500
Sticky throttle plate? Loose blade?
I've seen this happen when one of the blades gets a little loose. They'll shift and give you a intermittent condition.
Or the shaft will gum up.
Or the throat will get a build up of gummy shit from the fuel fumes that accumulate.
I recommend you clean your throttle blades, shafts and throttle body throat/s with a shop rag and some berryman/chemtool carb clener. I do it every so often on ALL EFI cars. Can't tell you how many customers have gone off happy as hell for very little money (it's a common problem with EFI cars).
I always tell people to START WITH THE BASICS. Don't just automatically jump to the conclusion that it's a bad tune, or PCM problem or something of that nature just because it is computer controlled. It can very easily be something real simple like gummy TB, vacuuum line off or split, etc. etc. etc.
I mean, if a car is overheating wouldn't you check the coolant content/level FIRST? Or would you automatically jump to the conclusion that it's a stuck t-stat, bad coolant sensor, etc.?
Basics my friends, BASICS.
I've had this problem since day one but only at certain times. Sometimes, it'll idle as high as 1800 for quite a while. I was told by SA that this was normal depending on the conditions. It doesn't happen often, but goes away after I pull away. I have found that it does it less if I let the engine slow down with it in gear (as opposed to coasting in neutral).
you should also buy some Mass Air-Flow Sensor Cleaner, while you're at it. you don't need to use much...just a couple sprays and let it dry. over-oiling your air-filter can also wreak havoc on the sensor, in turn causing strange behavior. not saying that's what you've done, but any kind of debris can cause issues with the sensor.
OP-
WHAT THROTTLE BODY DO YOU HAVE?
THE FRPP OVAL TB CAN SOMETIMES STICK, AND THAT WOULD RESULT IN THE CONDITION YOU DESCRIBE
IT HAPPENED TO ME A LOT, AND HAD ZERO TO DO WITH THE TUNE (WHICH WAS JON LUND)
JON LUND WAS THE PERSON WHO DIAGNOSED THE PROBLEM, AND NOW THAT IT'S FIXED IT'S A JOY TO DRIVE
BEST
PAT
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
