pue174
High Voltage Car Is Always Charging At 15.2 Volts
I have a 2011 with the FRPP 750 upgraded 2.9 whipple, I have noticed I am always at 15.2 volts. Does anyone know if this is normal for the 2.9 whipple tune?
Any ufo would be great. The dealer wants to fix it but can't figure out why it is so high. They have put a new alternator in and checked all the wiring and it still is at 15.2 volts
That is to high for any car. Even high output units only put out 13.5 volts. which is different than amps. Did they put a different gauge on the altinator? Your gauage may not be correct. A tune shouldn't have anything to do with the charging system.
Yes on multiple gauges. Tried different alternator and checked all grounds. No changes.
An update for anyone that cares. Brand new alternator installed, still at 15.2 volts Ford is pretty sure its the pcm most likely the tune from the pro cal that came with the whipple upgrade
They sent a data log to ford performance and we are waiting for them to look at it and diagnose
