gregsgs
My first oil change
Well time has come and I need to change the oil. I have looked around and found 2 different ways to do it. can anyone tell me the right way to change the oil and cooler and if it needs to be done in any order. also how much oil is needed to do it. can I get the filter at most auto stores?
any help would be great !!
Just follow the owner's manual and don't put a cheap filter on it. Unless you want oil all over your k member take some aluminum foil and cover it directly under the oil filter before you remove it.
8.5 quarts of Amsoil 5w50 signature series full synthetic and an Amsoil EA011 oil filter. Your shelby will thank you!
You can also avoid a mess by placing a gallon zip lock baggy over your filter when you unscrew it.
That's a good idea! :idea:
