Al d
How to spend $5-7K
I'm looking for advice since I'm new to Fords and GT500's. I want to take a new to me 2008 stock low mile GT500 and pump it up. I have $5-7K to spend. I won't be taking it to the track. HP and traction are the most important. I don't mind lowering it a little (1"), but only if it will make a big difference. It will be a Sunday driver only. I'm leaning toward the following, but haven't priced it out with any shops yet.;
Cold air intake, Pulley upgrade with tune.
Clutch/flywheel upgrade since I have the original.
Control arms
Shifter upgrade
Royal Purple Tranny fluid
Oil Separator
Thermostat
Am I missing any important upgrades? Is anything on the list not important? What else can I afford with my budget?
All opinions welcome.
Thanks in advance.
I don't track my car, but the two biggest improvements I've made are the FRPP TVS & utilizing the '13/'14 cf ds. These two changes greatly improved the performance if the car. I am still running the stock clutch and except for the Reische thermostat my cooling system is stock. Looking back I would've skipped swapping to a smaller pulley on the stock Eaton & went straight for the TVS. GL, Duane.
I have had some interesting performance cars, but never a supercharger before. I have always worked with naturally aspirated engines, so this is all new to me. One of the attractions to this car was the easy cheap HP upgrade with the pulley and cold air kit. Is the TVS the entire Supercharger? or just an upgraded part?. What type of gains would you expect to see swapping it out. Are you suggesting this for bang for the buck HP, or for reliability? Or something else?
Edited by Al d
I have done many upgrades in stages, and have to say, if I were you I would do the following. This will yield you big smiles, and giggles. Do without a dought Ford racing track pack suspension kit with adjustable shocks/struts (your car will handle like a BMW M3) no joke! Next I would do the short throw shifter. Followed by intake, 2.6 pulley, tune and spark plugs. JLT sells a kit that has all the following and it works wonders. Enjoy your new found power and handling.
Mark
Any guess what that suspension will cost installed? What kind of HP gain should I expect?
Thx
Suspension cost and installation should run you around $1800, JLT performance package is a little over $1000 install run you $200. Get the Ford Racing 65mm Throttle body $450 and you will have a hell of a set up. I made 545RWHP with this set up, and man was it a huge difference. Besides over-drive pulley, the next step to get more HP would be blower swap, but that gets pricey
Mark
Looks like you have done your homework, you have many good choices on your list.
If I were to build another one from scratch with your budget, this is where I would spend my money on in order of importance:
Twin disc clutch (Mcleod RXT or equiv)
1 piece aluminum drive shaft
Rear upper control arm bracket (BMR)
Rear upper control arm (BMR poly bushings)
Rear lower control arms (BMR or Shelby billet poly bushings)
Adjustable rear panhard bar (BMR)
Royal Purple Trans Fluid
TVS blower, 2.6" pulley and 90mm idler (VMP Gen II)
123mm CAI (JLT)
SCT tuner and a good custom tune for max pump gas octane (VMP)
1 step colder Ford plugs
Passenger side oil separator (Shelby or JLT)
Ford Racing KR short throw shifter with Ford Racing arm and ball
This will give you plenty of power (around the 700hp crank range), with room to increase HP later on if you want.
Keep in mind that a better design blower will give you plenty of boost with less turbulance and heat build up with its improved internal design.
With that power and a set of drag radials, it is plenty enough to get you into the low 11s or high 10s at the strip.
Later on you can add some bigger injectors, a dual 67mm throttle body, smaller upper pulley and some pump boosters, and can easily get into the 800+hp range.
I have found that lowering the car and a lot of other suspension mods does not help much for strip racing, that is more geared towards track racing.
Increasing from 700+ hp to beyond is one thing, but getting that power to the ground and be usable is a whole different story though.
Another mod that you might want to consider eventually is changing the gears to 3.73s, as it makes the car much easier to drive on the street and strip.
The only consideration for that upgrade, is that many have encountered excessive gear noise when changing out the gears.
I avoided that myself by installing a complete factory assembled svt 3.73 axle assembly and it is just as quiet as the original.
If you have any questions, fire away.
Edited by msb64
That looks great. Can I do all that with my budget?
I am trying to narrow the shops down, but should probably ask them.
Don't forget a set of good tires. Power is no good if you don't have traction. If you have the stock Goodyear's dump em.
fortunately, for you, lots of people have been down this road before so hopefully you can benefit from that...
  • Cold air intake, Pulley upgrade with tune. <-- for the amount of money you have to spend this is a good idea
  • Clutch/flywheel upgrade since I have the original. <-- if it ain't broke, don't fix it (yet)
  • Control arms <-- not necessary
  • Shifter upgrade <-- necessary
  • Royal Purple Tranny fluid <-- don't count fluids, those are a given
  • Oil Separator <-- passenger side only
  • Thermostat <-- not necessary
here are the other "must haves"...
  • heat exchanger
  • larger intercooler reservoir
  • suspension kit (stabilizer bars/struts/springs)
  • adjustable panhard (cheap option) or watts link (highly recommended)
  • lower control arm relocation brackets (highly recommended)
  • grippy tires
  • mufflers (if you want an aggressive sound)
Edited by 2007red40thGT500
things that are nice to have, but NOT REALLY NECESSARY for someone in your budget and with your goals are...
  • supercharger upgrade
  • headers of any kind
  • mid-pipes of any kind
  • differential gears
  • driveshaft
  • throttle body
  • upper and/or lower control arms
  • brake upgrades
  • radiator upgrade
  • fuel injector upgrade
  • fuel pump upgrade
  • MAF housing upgrade
  • colder spark plug upgrade
Thanks for the help. I took the suggestions and made a long list. Now with the help of this site and the internet, I am going to do my best to research each one so I can prioritize. I doubt I can get it all done for $7K, so some of it may have to come down the road.
Everything other than the clutch upgrade, can be installed in a garage with jackstands and modest hand tools.
If you can do the same, the the labour savings can go into upgrade parts instead.
Even for the blower swap, I would consider a bolt on, it is that simple.
If you take your time and can follow instructions, it is not that difficult.
Btw, your $7,000 US upper limit is no small amount, convert that to CDN with exchange and taxes at the border that converts to over $11,055, not including shipping.
Should mention a few cool, useful and lower dollar mods that you can add on at any time.
MRT Antenna Shorty 13.5" assorted colors (CJ Pony) black $21.99 / custom color $29.99
Redline Tuning Hood Struts (Redlinetuning) $89.99 steel / Elite version $119.95 stainless
Raptor Single Stage Shift Light (CJ Pony) $114.99
LED map, trunk and license lights (eBay) < $20
All are very easy to install, with the exception of the shift light which requires you to carefully tie into one of the coil pack wires for the trigger signal.
If you are not experienced in electrical wiring, you might want to get a buddy who has some give you a hand with that.
If you search the forums, you should be able to find some really good install instructions/photos/videos for any popular mod or upgrade.
Before you do Any of the above. First, read up on the Internal improvements that went into building up the stock '13/'14 year GT-500s over its predecessors. You would be amazed at what it WILL take to make your 08 KR capable of "maintaining" your desired amount of Horsepower requested...... Getting it isn't the problem my friend. Maintaining it with what I've read you're proposing to do certainly is. 2014 Shelby SVT TP/PP GT-500. Slightly modified to 745 FWHP.
Edited by Altruism
Mods listed above by several people have been proven many times over, most are common sense upgrades.
Some of the oem upgrades are for specific applications and more extreme climates, and not applicable to everyone.
Many of the oem upgrade parts are based on what aftermarket companies and Ford Racing improved upon in the first place, many of those parts were available before the new models even hit the streets.
Good Luck with holding that Block together in the long run, at least with no "Real" listed internal Upgrades. Obtained .... Absolutely. Maintained. .... Doubted. :-).
Whichever route you go on your engine just be sure to utilize a safe tune from someone reputable, good fuel and try to keep your rpm's under 6500. These engines are very durable but everything has their limits, including the '13/'14 5.8s
Contact Revan Racing, Van Collier, @ (561)445-7702. He will give you honest direction & advice based upon experience & seat time. Enjoy your new ride!
There are things you can do to increase longevity on any motor.
08KR525 has the right idea, if the stock motor is not built for high rpm, then don't buzz the motor.
I set my shift light to 5800 and my rev limiter to 6200 rpm.
The car already makes plenty of power so there is no need to push the limits.
I went with an ATI super damper to help reduce the added vibration at increased power levels.
With the 10% over lower, I run a 2.6" upper to keep the boost reasonable.
Also increased to 56lb injectors and dual pump boosters to insure enough fuel, but still maintain near oem driveability.
The car sees nothing but 94 octane fuel, and the tune is built for that specifically.
The approach costed a few extra dollars and is on the conservative side, but I would rather be on the safe side than sorry.
Unfortunately there are no guarantees, even on a pro built motor.
All it takes is one failed injector or something similar to cause it to go lean on a hard pull and it is tear down time.
WATTS LINK/TORQUE ARM/LOWER CONTROL ARMS W/RELOCATION BRACKETS = $2,400 + install ($2,300)
PENDING OPTIONS
2013-2014 2.3L TVS (OEM OR PORTED) TAKE OFF FROM PRIVATE SELLER = $1,650-$1,900
2.9-3.4L WHIPPLE SUPERCHARGER FROM PRIVATE SELLER = $2,400-$3,000
2.8LC KENNE BELL FROM PRIVATE SELLER = $2,500-$3,000
YOU DO THIS GRIGGS RACING REAR SETUP (WATTS LINK AND TORQUE ARM) AND PUT A MORE POTENT BLOWER ON THE CAR I GUARANTEE YOULL THANK ME. I GUARANTEE YOULL HAVE A CAR HIGHER IN POWER AND SUPPORTING MODS THAN MOST OF THE OTHER MEMBERS IN THIS FORUM
Edited by super hiss
i call BS. theres nothing about the 5.8 that suggests its stronger or more reliable than the 5.4. the 5.8 is a bored out 5.4. it has plasma coating instead of iron cylinder sleeves and extra water jackets (ie holes) in the cylinder heads for cooling but is otherwise the same. the KR engine is iron and was proven in countless truck applications that the aluminum 5.8 was not.
Read it and find out the facts from the Engineers who built the internal components for the Trinity Engine. 2,000 psi of internal pressure of the cylinders (vice 1,600) will actually crush and flatten the piston heads on the old Condor 5.4L engine,needless to mention anything about the Oil Squirter required to keep this 20-30% more stock power motor for this Superior Beast out in front of its 5.4L predecessors . ...... Loving the Haters.
http://www.mustangandfords.com/news/m5lp-1203-2013-ford-shelby-gt500-trinity-5-8l-v8/
Edited by Altruism
i'm not hating at all. we just dont need anybody shoving the 5.8 in everyones face. it has nothing to do with the topic at hand. dude has an '08 he wants to mod with a modest budget. im glad the 5.8 can handle a bit more cylinder pressure but who cares? you can also build a 5.4 however you want it and probably for less. none of that has anything to do with reliability anyway.
One thing I would recommend fitting in with other pieces and parts would be a TVS supercharger upgrade from VMP Tuning: http://www.vmpperformance.com/Supercharger-Upgrade-s/209.htm
Particularly if Justin is still working there. He was above and beyond helpful with a lot of questions I had before, and after ("After" is a big part of how I personally measure customer service), I pulled the trigger on a couple of upgrades I did.
Just one thing and my personal opinion of course.
I can't speak for all, but I like the 07-09 body style the best of all so far, so going to the newer style body would not even be a consideration for me.
The front ends are not bad, but the back ends just don't do the car justice.
Beefing up components and boosting hp is easy enough to do though, and offers the best of both worlds for my application.
