larryeod
Engine Codes
Can anyone decode this for me. 9M318 03210936. I think the first number indicates the build year of 89. Not sure about the M and then of course 318 is the engine size. I have no clue about the last 8 numbers.
Thanks Larry
those aren't engine codes, they're block casting numbers. the first group are a date and c.i.d. number. the second set, is the actual cast number, for the block. moparts.com is the place to go, for detailed engine info.
