KOBRA2848
Passenger Side Leak
With all the rain we had in South Texas this morning on the way to work I noticed a little water on the passenger side mat. Upon pulling the passenger cowl cover to access the cabin filter there was a couple inches of water. Upon clearing the rubber drain of a buildup of leaves and dirt the water drained quickly. The driver side was also clogged. Both drains are accessible from the engine compartment and a quick squeeze will clear any obstruction. I will definitely be checking these drains more often. Hope this prevents someone else from having the issue.
Mark
The water leak was/is a common problem with the S197. If you use the search box function in the upper right of the screen and type in "water leak" you will get dozens of topics and posts about this issue going all the way back in to 2006.
Edited by mhr1961
