So started my rear tow hook project
Using FRPP part #M-17954-RA
location
bumper cover off and location marked
Tomorrow to my welding buddy
Subbed... I can't wait to see the end result. If I get into racing, I'm going to want to do a tow setup.
$40 later and a fresh coat of primer..............top coat of performance white tonight
Was missing a impact bar bolt only had 5 out of 6 on the car....welder friend had an extra corvette bolt ughhhh better then a trip to the stealership or Ace and no time to order from Tasca
Edited by andrewnagle1964
mocking up the license plate bracket.....Blue Ox BX88290 Spring Loaded License Plate
still waiting on a coat of paint to dry on hook
and need to go buy stainless steel nuts & bolts
  • Like 2
Looks like your missing the small piece for the back side at an angle to support?
If the intent is to use this while on track, you may want to remove the plate while tracking as track workers will be able to easily see the tow hook.
Edited by stngfever
wondering where the hell that plate went ughhhhhhhhhhh
Oh boy! Shouldn't be hard to have a piece made and welded in.
Just talked to welder friend and can make a piece and add it. He welded the small piece at the bottom & behind the bracket and on the third raised bumper row said it fit right there.
better now then later........
Thanks for the input and photo !!!!
Glad I could help!
finished up tonight and i forgot the gosh darn foam inserts....had to take it apart and do it again
  • Like 2
Ha! I did the same with my front bumper when I attempted installing my front tow hook. I've been carrying that foam around in trunk for a several years now. I'll have to correct that this Spring.
Thanks, by the way very nice install, Thanks for sharing the photo instructions also.
Is the rear bumper crash beam not spot welded on there? You can really pull the vehicle by this bar only held onto the car with 6 X 18ft/lb bolts?
Haven't used the rear hook yet, I think this weekend I will hook it up to the truck and see what happens before I need it. Have you used the front hook to pull it up onto a rollback.
unfortunately I have "tested" the front tow hook after an off track excursion. Works great.
