Bad Horse
Intercooler tank fluid
Any tricks on " burping" the intercooler system. No kinks in the lines and I have wired a switch to power the
pump which is running .How long should it the take to primp the pump?
Found the trick...squeeze the hose from the bottom of the tank to the pump about 10 times and it took right off.
:thumbsup: Yep, squeeze, with both hand if possible, on the bottom hose.
If that doesn't do it, you can disconnect the lower hose, use a funnel to add new fluid into the top tank and let gravity push out the bubble. The second option will lose some fluid, but if its stubborn, might do the trick.
