Cobra37
wheel size
What will happen if I put 20" wheels on all four corners of my 2012 Shelby?  It has 19"s on the front originally, so will the 20"s screw up my steering or wheel clearance?
You would have to resize the tires to keep the same radius.  It is possible that keeping the same wheel sidewall size (ie, also increasing tire radius) would work but it is also possible that the wheels would rub or contact on turns and bumps.  You'd have to check.  Tire Rack can usually tell you if it will work.
