SamuelMur
My Ford broke down.
Hello! Something happened with my Ford. The engine began to run unevenly, appeared to vibrate, and the oil consumption increased. Has anyone encountered this problem? What is the reason?
Wow, you're not likely to get too much help here.  This is primarily a Mustang group. I assume by your posting in the Ford GT forum here that you own a 05-06 Ford GT.  There are a few GT owners but not many.
Whatever it is it doesn't sound good.  I see you're in Europe.  Have you sought out a Ford dealer over there?  Running rough could be a plug, but increased oil consumption isn't good (I'm surprised you ran it long enough in this state to determine that).  Do you see smoke from the tailpipe?   Something this bad would probably throw a Check Engine Light - is it lit?  Have you pulled the code (if there is one?)
You might try the Ford GT forum (since you're an owner, you'll get in) at www <dot> fordgtforum <dot> com (for some reason the word forum is disallowed ...  That forum is dedicated to Ford GT owners.
Edited by twobjshelbys
