mdub61
Wheel Size?
Can someone tell me the maximum size rear wheel that will work on the 2013. Trying to go to a wider tire. thanks
Edited by mdub61
Just put on 295 Michelin PSS on the stock 13 GT500 rears, the look and fit great. I’ve seen 305s on others, but don’t care for them. Installers likely won’t install larger than 305s.
1 hour ago, mdub61 said:
cam you tell me the width of the wheel? would it be a 10?
My Velgens are 10.5 but not sure what the stock GT500 wheels are.
Edited by Secondo
If you are asking about widest wheel size, and not widest tire on stock/oem wheels, I believe the 2013 owner below has 12" Alcoa's on the rear.......
^^^^^^^^^^and 10" Alcoa's on the front, I'm pretty sure. If I remember correctly this owner had asked me some questions about the 10"/12" Alcoa set up on my 2008 before he went into that project.
Edited by Robert M
The OEM rim is 20x9.5.
295/35 is the widest you should properly install.  Others go larger, but they end up wrapping on the sidewall and the effective contact patch with the ground is often equal or less that a properly sized tire.
