Last few weeks I kept hearing a loud clunk coming from my trunk when I went over bumps. Checked the trunk but nothing. So I reached under the car and hit my rear swaybar. Yup that's the clunk sound. I can't see well enough if its bushing or just loose. Car only has 28k miles.
I was wondering does my mechanic need special bushings or is it the same part number as a Mustang GT?
Thank you
Sway bar bushing set for Shelby GT = #M5490A.  Regular GT bushings will not fit.
Just had mine replaced a couple months ago. They will bind for a bit before settling in, so you might hear a different clunk or groan after installation.
Only use silicon based lubricant. Regular grease eats the poly bushings, which might have happened to your SGT.
https://www.cjponyparts.com/ford-racing-sway-bar-bushings-for-frpp-sway-bar-m5490a/p/M5490BKA/
Edited by BlackSGT
The “clunk”, “thunk”, squeak is not uncommon on the SGT. The bushings on the SGT  are Urethane. Before replacing them you may want to try lubricating them with the proper grease. Do NOT use petroleum based lubricant. Below is a link to a thread about it with a write up about the proper lubricant to use.
 If you do a search within Team Shelby , for “rear sway bar noise", "bushing squeaking", "rear clunk" , "noise form rear end" you will see several topics about it.
My SGT has about 33,000 miles and occasionally “clunks” but the bushing are fine.  If the clunk comes back I just lube them.
Please take car into a muffler shop and have them check your mufflers...I had some American Thunder Flowmaster Classic axle backs installed last summer as I wanted a slightly louder tone than stock....exhaust shop mentioned how loose the OEM mufflers were.  I do not know if they were loose in the hangers or at the connection with the flow tubes, but after the install the clunk/clank I would here over speed bumps etc. was gone.
the OP already mentioned that he reached under the car and bumped the sway bar and heard the clunk. Yes, there is an outside chance it may be a muffler hanger or exhaust issue but it is more likely it is bushings that needs lubricating or possibly replacing if lubrication doesn't eliminate the problem. Lubrication first, because that may be a $1.99 cure rather than start tearing in to the car replacing bushings or repairing/replacing exhaust components.
It's all good. I had the loose muffler situation myself, along with the bushing clunk. A small tube of lubricant cured the "clunk". Then had the rattle the muffler was causing fixed at Midas.
Edited by mhr1961
Love these blasts from the past, most of us who have been on the forum for a long time with our purchase of 07/08 Shelby GTs went through some of this.  Went back and  checked my notes on an e-mail copy from SAI Bud on this.  He states most common rattles were from broken exhaust welds, loose rear shocks, and not enough lubrication on the sway bar bushings.   I have had and fixed 2 of 3.  Never had a loose rear shock.   The weather always had a lot to do with it.  I just WD40 and it went away.   Some had more squeaks than others.  Usually a twice year squirt.   Just my thoughts...…….. GG
Does powerflex sell grease for a grease gun? On my sgt the rear bushings have zerts for rear stabaliser bar. Is the grease clear?
Just a little heads up. My bushings arrived. Quality appears poor and they are all black not as they appear on the website.
I discovered that a couple of years ago when I replaced mine. Be careful taking apart the end links. It is real easy to strip out the hex heads taking the old bushings out. I replaced mine two years ago and they are still quiet.
Mark
